I want an energy efficient blower fan motor, and have seen in other threads these referred to as ECM. What does ECM mean? Are all the variable speed blower fan motors ECM, or do I need to specify that?
Normally a furnace is rated in BTUs and cooling in tons (but you may also see cooling specs in BTUs). The 3.5 ton number you see on the furnace is the blower rating, meaning it can support a 3.5 ton (42000) cooling unit (blower has a max of at least 1400 CFM).Is a three ton gas furnace going to say 36,000 btuh output, or are they measured differently? I am confused because one quote says 3.5 ton furnace at 57,000 btu. I would have thought 3.5 tons was 42,000.
PS-- Sorry--Meant to make separate thread.
Hmm. I'm a little simple so I don't quite understand this. Does the gas flame become less efficient as the furnace size increases? Does the flame become hotter and waste more heat up the chimney as the furnace size increases?Th eproblem with over sizing a gas furnace is that you waste energy...
