what gets pipe dope out of clothes?
70K views 27 replies 24 participants last post by  Answer-Man
#1 ·
Everytime I get a new jacket or batch of work clothes, it finds me. Lurking in dark shadows of basements, and waiting to get me.
How do you get it out of yer clothes? I know they are "work" clothes, but I hate looking like a slob. Always seems to come back, no matter I use.
#5 ·
Tried to post this the other day on the "Cologne in Eyes", but got into an endless loop that I wasn't logged on. Try Men's, or I guess ladies, cologne. Rub it into the spot and laundry as usual. Could get magic marker out of clothes and the Red never-seiz grease we used on towers. The PST sealing dope can only be broken down by Acetone. The Black Carhart jackets should be dry cleaned or they will rapidly fade. PS If you have compressed air in your house run a tap over to the washer, works great for pushing prespotters back and forth through stains. Do not use this method on flammables!!
#6 ·
Try the hand wipes that you buy I don't remember the brand of them but I used one to remove keytite pipe dope from my pants and they worked great. I did this before laundering them I don't know how it would work afterwards. I think they were the blue ones and manufactured by loctite.
#8 ·
gotta get the stains before the dope dries - I have used grafetti remover with success - good luck
Save
#13 ·
Pipe Dope Cure
Belive it or not. Motor oil is the cure. We used it on drill rigs to remove the ORIGINAL pipe dope from hands clothes, etc. Just smear a bit on the stained area rub the mateerial together and launder as usual. No it is not a good deoderant but it does semove the stain...
#15 ·
Pope Dope
Don't know about teflon based>> The pipe dope used on drill rigs sticks to everything. We used to keep a 5 gal. bucket on the drill floor to clean our hands before the guvmnt told us it was harmful. I used it for 20 years and still have my hands. I guess if I live long enough it will eventually kill me.
He who laughs last, thinks slowest :
#23 ·
Use MOTSENBOCKER LIFT-OFF it's a Silicone Latex Caulk and Foam Sealant Remover. Bought it initially to remove foam sealant from off of bricks and used it again years later on clothes to remove pipe dope; took less than 60 seconds to remove the stains.
Note: WD-40 did not work for me and left WD-40 stains :gah:
#26 ·
That's Brilliant! I use that stuff fairly often for silicone - so I always have it in the truck.
Thanks!
PHM
Save
#24 ·
jamathi
Welcome to the site.
Do you realize this is 12 to 13 year old thread. There are only 1 or 2 still active in this thread. Please use a newer thread for comment or start a new one if you wish to comment about the subject.
Good Luck and Welcome.
#25 ·
Anything alcohol-solvent based is hopeless. Leak Lock and all the rest - learn to live with it.
If you use an oil-solvent based dope you can sometimes find WD-40 to be effective.
I tend not to touch anything 'dirty' with anything except my hands. So much so that it is commonly remarked: "How come you're never Dirty???" But if that is beyond you - my fall-back plan is to don a good set of cotton coveralls for working around dirty things - like oil boilers and mechanical rooms. Oh; and pipe dope.
PHM
Save
#27 ·
Buy yourself a lab coat. Used to work in one facility and we had to wear the hair nets... booties... and a lab coat..... I loved those coats....
For winter time... outdoors..... just buy yourself a coat you can sacrafice for dirty work..... and the same goes for pants..... change when you leave the job
Save
#28 ·
Corny did just remind me of my early years. I used to keep several pairs of coveralls in the truck to slip on. Heavy weight for winter and very light short sleeved one for summer. Which worked great for the pipe dope type of issue. I changed to just keeping a change of clothes and shoes for those times I got scuzzy. I also have one pair of Tyvec coveralls just in case.
