To get maximum air cleaning, do I need to have thermostat fan setting to "ON" or will CIRC" setting clean air just as well. According to tech that came for routine service, I was told fan setting had to be set to "ON" for the electronic portion of the filter to be working all the time. The tech said that if you use the circ setting the electronic portion only comes on when furnace starts. When first installed, I was told to use "Circ" setting for keeping air purified. Just need some clarification on advantage/disadvantage of using ON or Circ for maximum air quality. Any clarification would be appreciated. (In particular, on the circ setting, is the electronic portion of CleanEffects working at all other than at startup? ) Thanks Rick
