Summer is here and needless to say my attic is hot. I've recently moved into a Cape Cod style home in the Philadelphia area and would like to install a gable exhaust fan on one of my end gable vents. My attic currently has two gable vents, one on each side of the house and a rooftop ridge vent.
My question is, if I install a gable fan will I be messing with the "fundamentals" of how this existing venting system was engineered to work? My understanding is that the ridge vent would pull air through the gables and out the top ridge vent. By installing a gable fan I would be changing that flow to pull air towards and out the gable, no longer the ridge vent.
Do you recommend that I install this fan or come up with another plan? The temperature in the attic is way to hot and I need to start moving some air up there.
-M
-M
