Rheem Prestige 96V - Error Code 45
4.9K views 6 replies 5 participants last post by  jdaltman9
#1 ·
Hello all - hoping someone can give me some direction. I have a 5 year old Rheem Prestige 96V unit. I turned on the heat for the first time last night - everything worked fine and hot air was blowing until the house warmed up. Woke up this morning and the furnace wasn't working. Bumped up the thermostat and nothing. When I check the furnace - I could see when it tried kicking the heat on (lower case h) and then would eventually throw the error code of 45. Thanks in advance!
#3 ·
Site rules prohibit giving DIY advice.
Save
#5 ·
If the installers left the installation manual behind, it will tell in there. That's the farthest I can go. I think I know what it is and if so, would need test equipment to find out of bad component or it's doing its job and flagged a problem.
#6 ·
Thank you for your graceful response, have a wonderful day. :grin2:
Save
