He is correct and latent heat IS the answer. Specifically the latent heat of vaporization of water. Let me explain:
When you put a pot with a gallon of 65 degrees tap water in it on the stove and turn on the heat, you will have to add 1 BTU of heat energy to raise the temperature of the water 1 degree Fahrenheit. So, from 65 to 66, 1 BTU. From 66 to 67, 1 BTU, and so on. Until you hit the boiling point, that's where something entirely different happens. In order to convert that 212 degree water into 212 degree steam, NO change in sensible temperature, you have to add 970 BTUs of heat energy. 147 BTUs to go from 65 degrees to 212 degrees. 970 BTUs to not even change the temperature one degree, just convert it to vapor, boil it away. That's the power of the latent heat of vaporization. (There's the latent heat of fusion too, ice, it's 244 BTUs per pound of water, that's how ice keeps your food cold in your cooler at the picnic.)
Your air conditioner also dehumidifies, since generally the evaporator coil above your furnace or in your fan coil is about 40 degrees and usually below the dew point. So the reverse is true, every gallon of water your air conditioner condenses out of the air HAS to also release 970 BTUs of heat energy into the coil to be carried away by the refrigerant inside. That energy does nothing to change the temperature of the air, only remove water from it.
Enter the dehumidifier. Every gallon of water it extracts from the air is 970 BTUs of heat energy your air conditioner does not. Now your air conditioner can go to work actually cooling your home rather than dehumidifying it also. Well, it will still dehumidify, but it'll have to work less moving that heat energy out of your home, to the outside via the condenser.
And, you'll have much better humidity control.
Science. Isn't it cool?
Sent from my Pixel 6 using Tapatalk
