Adjusting a Ranco 10-1409 temp control
6.1K views 8 replies 4 participants last post by  hvacskills
#1 ·
I read somewhere that the easiest way to set this temp control would be to turn the differential screw up to the maximum differential number, set the cut in temp and when the box gets down to the temp you want you then turn down the differential screw until compressor shuts off. Does this sound right to you?
I am trying to zero in one of these units.
#5 · (Edited)
ItÂ’s attached to the coil. Current cut in 38*f and cut out 34*f box temp.
Trying to bring her down to 30*f cut out.
is this for the Pepsi cooler ? if it is attached to the coil that would explain the difficulty you are having .... not sure the differential is going to be large enough .....
you are correct, you want to adjust your cut in first .......
for a 32 - 38 degree box, 35 degree beer
unplug cooler, set cut in on dial to 34 degrees, set differential to maximum, plug in cooler, once box hits 34 degrees raise cut in on dial to 42 degrees, adjust differential to minimum, compressor should cut off, adjust differential to maximum, allow box to slowly rise to 38 degrees, as box approaches 38 degrees slowly lower cut in temperature until compressor turns on, as box approaches 32 degrees slowly lower differential until compressor turns off ......
if you want different temperature settings substitute the 32 and 38 for your own numbers ..... if it is for the Pepsi cooler and you want it cold I would run the box between 32 - 38
Save
#7 · (Edited)
cool .... or should I say cold ? ..... that is going to be some cold beer ...
curious how did that affect or what are your cycle lengths now ?
and you are right, it takes piratically forever to get the charge and the thermostat setting on these small little boxes exact ..... but once you do they run pretty much trouble free .... knock on wood
Save
#9 ·
that is nice, that is around 2 cycles per hour, compressor should be a little bit happier ....
you are welcome but you are the one who did all the work glad I was able to give some advise ....
really nice job !
Save
