Results 1 to 8 of 8
Thread: Great building science blog - Energy Vanguard
    Rochester NY
    Here's an interesting article on radiant barriers. Haven't finished reading it, maybe my prejudices against measures outside of the thermal boundary will be proven false...
    Early Adopter round is OPEN - https://www.hvac20.com/earlyadopters.html HVAC 101 free pdf - http://bit.ly/HVAC101File1118
    Jun 2001
    Great article. We did an informal attic temperature test in our attics a few weeks ago when temps were 105 outside. Wind was about 8mph.
    1: Ridge vent house was 155
    2: Power vent house 145
    3: Attic turbine house 145
    4: Radiant barrier stapled to underside of roof 125
    Based on the informal test in our neighborhood it seems the radiant barrier is what REALLY works !!
    SW FL
    Hmm
    Quote Originally Posted by 54regcab View Post
    Foam insulation roof joists ... 114.?
    Designer Dan __ It's Not Rocket Science, But It is SCIENCE with Some Art. _ _ KEEP IT SIMPLE & SINCERE ___ __ www.mysimplifiedhvac.com ___ __ Define the Building Envelope & Perform a Detailed Load Calc: It's ALL About Windows & Make-up Air Requirements. Know Your Equipment Capabilities
    Jan 2011
    Ward, Arkansas, United States
    Reflective roofing material? Wouldn't that be best?
    "Gentlemen. You can't fight in here. This is the War Room!"-Dr. Strangelove (1964)
    Rochester NY
    Quote Originally Posted by dan sw fl View Post
    No Dan, the first summer after spraying my attic it was never more than 5f hotter than outside. That was before AC in the house.
    I recently redefined a small commercial attic, they went up there the other day and it was 1/2 way between indoor and outdoor temperature instead of the typical 25f hotter than outdoors.
    The 2 ton unit cooling the space was able to keep up for the first time. Never done that before with OD temps above 85f.
    Some of my spray foam jobs.
    Jan 2011
    Off subject but one of his blogs he mentioned "Pressure Relief in Master bedroom" when mentioned proper HVAC design.
    What does he mean by that?
    Fort Worth, TX
    Hmm...article says same thing about PAV I have...that using a PAV is addressing the symptom, not the source. That pumping out hot air with a PAV means that all of the construction materials had to get hot first in order to heat the air. And that they're still hot even with the PAV running.
    Go radiant barrier!
    I also agree with comments below in the article where if no ducts reside in the attic, and there's a reasonable pressure boundary at the ceiling/attic floor juncture, better insulation is more effective in this case than RB.
    Psychrometrics: the very foundation of HVAC. A comfort troubleshooter's best friend.
    south louisiana
    in addition to florida solar energy center having good rb info
    oakridge also has good articles.
