+ Reply to Thread
Results 1 to 6 of 6
Thread: ceiling mounted climatemaster geothermal heat pump, i need help
    Jun 2011
    Confused ceiling mounted climatemaster geothermal heat pump, i need help
    i got a government building that has just recently installed 47 ceiling mounted geothermal heat pumps. they are all climatemasters. i am having a problem with a handful of units that are going into a lockout alarm. pressures are good, they run for a period of time (some run a few hrs and some run for a couple days) and when they lockout the fan continues to run. condensate is clear, freeze protection checks out. i am about to change out the control board on 1 unit. anyone got any experience with these climatemasters, have you had this problem and what you did to fix it?
    Nov 2007
    Central Alabama
    Model numbers would be nice information to have. What code is it giving you?
    Jan 2003
    SE Pa
    Sounds like water flow problem. Have you checked screens on these units?
    Always seems like there is dirt in lines no matter how much flushing is done.
    5 out of 4 people don't understand fractions
    Dec 2009
    northeast pa
    Do they have flow restrictors?How high is your water level in the tower sump
    Nov 2010
    Missouri
    I also would check your y strainers screens
    Jul 2011
    indiana
    Dirt,dirt,dirt......in other words water flow. Also water temperature. Check that beafore you start replacing control boards.
    Sent from my SGH-T989 using Tapatalk 2
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
