Page 4 of 4 FirstFirst 1234
Results 61 to 63 of 63
Thread: Cold Plasma Air Purification
  1. #61
    May 2018
    Quote Originally Posted by kdean1 View Post
    Here are a few articles from various sources in the industry. There are many concerns about inflated claims and failure to reveal potentially harmful side effects of IAQ gadgets from UV to ionization.
    https://www.energyvanguard.com/blog/...r-air-quality/
    https://www.pbs.org/newshour/health/...U04cdmuoU-zn-A
    https://medium.com/open-letter-to-ad...o-bc1570b2fb9b
    https://www.classaction.org/blog/fal...JQNcHPjKQ7FF6Q
    Thanks for posting those links.
    I’m going to pull the fuse out of my Phenomenal Aire bipolar ionization unit today and see if there is any change in the VOC levels in my encapsulated crawl space. (I have an Awair Element Indoor Air Quality Monitor currently in the crawl space and when the HVAC, a downflow unit, kicks in under heating or cooling, the VOC levels spike.) Today, the crawl space VOC levels rose from 93ppb to 850ppb when the HVAC kicked on under heating. Under cooling, the VOC levels can climb to 2,500ppb or higher. I don’t know if this is a result of our living space air mixing with the crawlspace air or if something in the supply line is causing the spike. I’ve read that an increase in temperature and humidity will also cause more VOCs to be released, but I wouldn’t expect that result to be immediate. Of course, this air quality monitor is a $150 device, so maybe the spike has something to do with the way this unit senses VOCs.
    The ionizer is located: Filter >>> Coil >>> Fan >>> Ionizer>>>Supply Line in crawl space
    Once the VOCs spike, they tend to remain elevated until fresh air is introduced (opening the crawl space door) or once the HVAC has remained off for hours.
    I have a Santa Fe dehumidifier in the crawl space and keep the relative humidity averaging 51%. The temperature is a near-constant 69 F.
    If pulling the fuse on the ionizer doesn’t shed any light on the situation, I guess my next step would be to install an ERV, but I would love to figure out a passive solution over adding another mechanical patch.
    -Frank
  2. #62
    Athens, Ohio
    Quote Originally Posted by Frank10 View Post
    -Frank
    You're welcome.
    I suggest that instead of adding an ERV, which adds a LOT of moisture, you can add a fresh air inlet to the Santa Fe.
    Teddy Bear can advise you on the most effective method for that.
    Ken
    Site member map HERE!
  3. #63
    May 2018
    You're welcome.
    Ken
    Hey, Ken.
    Thanks for the tip.
    -Frank
