Results 1 to 13 of 13
Thread: Err 79 on Trane XL16i - Anyone got the code list?
    Arizona
    Hey guys. Been a while.
    Anyway my friend just told me that one of the XL16i's I installed last year in California has error code 79 on the display.
    I don't have the book and I don't work on residential anymore (or even out in the field) to be familiar with it.
    I tried to search the internet but no luck. I see err 80 is High Pressure Cut Out. Maybe this is LOW pressure?
    I wish I would have kept one of the manuals. :-/
    Arizona
    Quote Originally Posted by PaysonHVAC View Post
    Give me a minute.
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    Arizona
    Update:
    Friend called and said they found fuse blown for OD unit.
    But they still want to know why it threw the code.
    I'm sure it has something to do with the communication error with the OD unit being DEAD.
    BTW, I said Trane XL19i, it's an American Standard,. Same difference.
    The units run all the time in the application they are used for.
    I guess maybe that's why the fuse blew after 8 months.
    Not much off cycle on these units.
    Arizona
    Low pressure cutout. Also does say if the power is interrupted to the outdoor unit it can throw the 79 code. seems like thats what happened.
    Dec 2010
    Palm Beach,Fl.
    Your guess is correct. Low charge fault. A loss of power at the condenser will throw a 91 comm error. There is likely still a charge issue. Was it a high voltage fuse?
    Arizona
    Would that code occur somehow if the OD unit loses high voltage?
    I've only seen these units once. When I put them in last year. HA HA!
    From what I hear I think it's back online. Hope it's NOT leaking for some reason now.
    This place is 5 hours away in Moreno Valley/Riverside.
    I guess it's 95 degrees today which is hot for there.
    Arizona
    Yes it can show the 79 code as the as the low pressure switch will not be discovered on the communication bus.
    Arizona
    Quote Originally Posted by SoFlaDave View Post
    Yes, a high voltage fuse.
    Arizona
    It took me a few minutes to find the pictures.
    Here's what I installed last year.
    It's at a warehouse, place.
    Building is a lease so he will take his units when he moves.
    This was the ONLY system I had used the "Communicating" t-stats on.
    Actually two of the three are. Had to use standard Pro 8000 on the third system because communicating was unavailable on that one.
    Arizona
    I posted about this last year I think.
    Was a LONG 3 day weekend to install these.
    I did pressure check them overnight and no leaks in my welds.
    We did everything. Electrical, duct work and all. NOTHING was there.
    Had to live on MONSTER energy drinks that weekend.
    Arizona
    Quote Originally Posted by jimj View Post
    Cool. Then let's hope that's all that was wrong!
    These cool a room that have High Pressure Sodium lighting on a timer.
    When those run (all night) these units run 24/7 cycling between the 1st and 2nd stage, mostly 2nd stage.
    I purposely stayed AWAY form the XL19i twin compressor style because I didn't feel like driving 5 hours one way to replace blown start capacitors!
    I saw a higher failure rate in the XL19i's in Phoenix. No way I was going to use them on a system that I knew would by HARD STARTING those compressors all day and all night. The unloading Scroll seemed to be the way to go for me.
    Nov 2010
    My Trane just threw error code 79.02 after the painters blocked the intake with masking paper. So it looks like code 79 can be caused by a blocked filter.
    Jan 2016
    Our power went off 2 times yesterday because of weather
    I guess and we have had error code 79 come up 2 times
    on our thermostat screen.
