Results 1 to 19 of 19
Thread: TopTech Air Knight or Guardian Air?
    Mar 2010
    I just had my new Bryant Preferred Series Puron 3.5 ton 15 SEER heat pump installed yesterday and it is great. I also had the Bryant Perfect Air Purifier installed and asked that the Guardian Air purifier be installed along with it. Everything looks good and the air smells like walking through a forest after a rain storm but the purifier has the name “TopTech Air Knight” on it instead of “Guardian Air”. Is this the same thing just with a different name from a different vendor? Overall did I make a good purchase and is there anything I should know about this system? Thanks!
    Not sure what you have,doesn't sound like an air purifier,can you post a pic?
    Top Tech is a new line of things from the Carrier /Bryant distributor here in Florida,the filter cabinet I saw had some issues,but not sure that's the Air Knight, may be something entirely different.
    Apr 2010
    Rowlett, Texas
    Air Knight
    The Air Knight is exactly the same as the RGF Guardian Air unit. It is manufactured by RGF and packaged for Carrier/Total Line. According to RGF there is no difference in the 2 products.
    Jul 2010
    Air Knight vs. Guardian Air
    The Air Knight and the Guardian Air, both made by RGF, are the same in that they are both PHI (photo-hydro-ionization) air purifiers. They use UV light, not as a direct contact puifier, but rather as an activator for an advanced oxidizing process that creates hydroperoxides. These are circulated in the environment rather than requiring that microbials actually contact the light or other surface. Their efficiency is much higher than other conventional purifiers, with amazing effectiveness against a variety of microbes and odors, as well as formaldahyde, all without adding ozone to the environment.
    The differences are both in marketing and technically. The Top-Tech Air Knight is only available through Top-Tech distributors in the Carrier Enterprise family. But the technical difference is probably the most important: while the Guardian Air is 120v, the Air Knight is only 24v, making installation a much simpler process.
    Nov 2010
    Central FL
    CE Wayne is correct! The Guardian is also available now in a 24 volt model but the Air Knight includes the 40va low voltage transformer and wire nuts in the box with the unit.
    Since my first post on this thread, I have tried both the Air Knight,and the REME from RGF.
    Both are excellant at removing odors and VOC's, try them and you'll be selling them.
    Dec 2010
    Would you be willing to share your return statistics? I am concerned about all the reported ballast issues etc. Yes, I realize this may be a past issue.
    What type of isses have you seen with these units this year?
    Thanks a lot.
    Nov 2010
    Central FL
    Air Knight reliability
    Acurajeff...reliability is well over 98% based on just under 4000 units. We make sure to avoid any VA draw problems by including a separate transformer in the box which helps ensure our reliability
    Dec 2010
    Quote Originally Posted by AftMktGuy View Post
    That is good information as I thought we could delete the included transformer and wire directly to the air handler's 24V. It sounds like to ensure reliability, we need to use the included transformer and power with 120VAC instead of wiring to the air handlers's 24V. Is that correct?
    Nov 2010
    Central FL
    That is correct. Most equipment manufacturers would not want you to tap off of their transformer as it has been sized to handle what is neccessary inside their equipment.
    There are too many variable that can happen with the timing of equipment and the VA draw that may occur. Variable speebd equipment has different requirements than standard. To avoid any issue and to keep the warranty from being possibly compromised we suggest that that the packed transformer be utilized. Well worth the extra 45 seconds it takes to mount it where needed.
    Dec 2010
    Your insight is greatly appreciated. I initially figured that the upsized XFMR supplied by the Trane Clean Air Effects which replaced the Lennox Signature Series variable speed air handler's XFMR would be okay. It sounds like I need to find 120VAC some where to be safe.
    Dec 2010
    More Guardian Air Questions
    1. Is there any affect this may have on you air conditioner's (evaporator coil) drain pan. A lot of lights and oxidizing processes can damage the plastic. This can lead to an expensive a/c repair that can also cause expensive water damage to you furnace. Just like plastic toys and furniture become brittle and break apart, this can happen to your drain pan, fast. Then water from your ac leaks down the front of your furnace.
    2. Where does it have to mount? Because, if as in video I saw it mounted down stream on supply side trunk, if it must be there then do you have more that one supply trunk?
    The plumun sits on top of furnace and most furnaces are in the middle of house so the supply trunk splits and goes two ways.
    3. If you have a variable speed furnace I saw they have a special unit just for those?
    4. Can there be any effects from H2O2 on any persons respiratory system or mucus membranes and on fabrics?
    The reason is O3 (ozone) works great, but some people can't tolerate it, even at low levels. O3, dumps an O into the VOC's to (oxidize) burn them. This process can also break down fabrics. Now this claims not to be ozone, but it is adding H2 to oxygen molecule. I just would like to know more of how it is getting the H2 to add. Regular air is about 80% hydrogen and 20% oxygen, but how is it done, and what effects can the H2 oxidizing process have would be my question, because in the end it is doing the same thing as O3 just with H2. If none then this could be great.
    Nov 2002
    MIDDLE TENN.
    Smile toptech
    do you wire this unit to stay on constatly, or do you add a relay to bring it on when the fan comes on?
  14. #14
    Nov 2010
    Central FL
    TopTech
    Kowboy...look at the ballast of the AirKnight the same way you would a striker for a torch set...you only get so many strikes out of it. We subscribe to letting the light stay on all the time to extend the life of the ballast system. Turning it on and off all the time can shorten the expected life of the unit...but some of this would depend on how the system is run, number of cycles etc.
  15. #15
    Nov 2002
    MIDDLE TENN.
    OK- GREAT: I WAS THINKING OF ADDING A RELAY TO BRING THE LIGHT ON WITH THE FAN, BUT THIS MAKES MORE SENSE. THANK YOU VERY MUCH. MERRY CHRISTMAS
  16. #16
    Nov 2010
    Central FL
    TopTech Air Knight
    Kowboy....you want it on all the time. if you cycle it on and off with the equipment you will lower the life expectancy of the ballast assembly. Same as a flourescent light.
  17. #17
    Jan 2011
    Lancaster county PA.
    Thumbs down reliability issues with guardian air REME.
    You definitely want to power the RGF product all the time. Our company was installing the guardian air phi cell a few years ago but had too many failures of the included transformers and or the ballasts so we quit handling them. Then RGF came to our shop to premier their reme 305 about Sept 2009. I specifically asked their tech about the reliability of the ballast system in the 305. He said,"yes we had some problems with the guardian air units but the new reme 305 has a much more robust ballast system". They offered our employees a special group discount to purchase for our own homes only. Many of us got them and liked how well they did their job so we started installing them for clients. Much to our dismay, more than half of them have already been replaced. Same problems as the old guardian units. Does not seem to matter if they stay on 24/7 or cycle with the fan, they still fail. When they are working, I like them a lot. I have one in my own home. It has been totally replaced once, after 4 months of constant use and that one just died 2 weeks ago. It lasted 11 months. 6 of us techs bought them for our own homes in sept. 2009, only 2 are still working. One of those has been on 24/7 the other one cycles with the fan. Good luck. Brian. PS Our company has quit handling their product until reliability issues are resolved.
  18. #18
    Mar 2012
    Does anyone have any experience with these, or any in-duct UV-light based purifiers with respect to cigarette smoke? We live in a condo, and have developed a cigarette-smoking neighbor. There's enough shared air that we know when he lights up, and would really like to get rid of the odor (and second-hand smoke). We're putting in a new heat pump now, so here's our chance.
    Thanks for any help!
  19. #19
    Nov 2010
    Central FL
    Joshfisher...based on what you describe, I do think the Air Knight PHI product can do a tremendous job of removing the lingering smells caused by the smoker...however I do not think it will do much to deal with it at the time the person is smoking.
    Without knowing much about the layout or options...I would suggest that you heavily consider using the law of physics on your side. If you can introduce a controlled, (preferably conditioned) amount of freshair into your side of the the home, it would give you a positive pressure. The positive pressure would then not allow the smoke or the smells from the smoke to travel into your space.
    But either way the PHI benefits are great. My opinion.
