View Poll Results: Attic or garage install for gas furnace?
Voters
29. You may not vote on this poll
  • ATTIC
    12 41.38%
  • GARAGE
    17 58.62%
Page 1 of 4 1234 LastLast
Results 1 to 20 of 66
Thread: Attic or Garage install?
    Apr 2006
    Tyler, Tx
    Confused Attic or Garage install?
    I am renovating an older home, it has window units and deerborn heaters for heat. My question is where would install the new furnace? Attic or garage are the only options as "the boss" doesn't want to give up storage space inside. Attic is open with enough room for an attic install, I can walk upright the length of the house, was also thinking about putting above garage for easy service access.
    What are you prefrenses and why?
    Apr 2006
    Tyler, Tx
    Also wuould you guys install round metal duct or flex duct? Asid efrom from price waht are pros cons?
    GARAGE!!!!!!!!!
    Metal is best but usually ducts in an attic are insulated flex. Get at least R6.
    Jun 2007
    The Twilight Zone
    Not a pro, but if the temps in the attic get hot, humid, and nasty in the summer, I would not put it in the attic. My 2 pennies.
    Good luck.
    Apr 2006
    Tyler, Tx
    If it was your house you would install metal ducts?
    Nov 2008
    Chapel Hill, NC
    Depends on the location of the garage - if its at one end of a long skinny ranch, you'll likely have one warm end and one cold end of the house. Get a good installer to give their recommendation. Whatever you do, get an insulated metal supply trunk and main return. Flex is OK for short branch lines off the main supply trunk.
    Apr 2006
    Tyler, Tx
    Quote Originally Posted by sktn77a View Post
    The garage is on one end, furthest run would be about 35 to 40 ft, from the garage. Was also thinking about spliting return to draw air from both ends of house.
    Prata di Pordenone Italy
    i would put it in the attic and run a ductboard trunk line with short runs of flex and at least 2 returns maybe more and a april air filter
    the airhandler should be located as center as possible to the areas serviced
    I don't know
    Garage - easier to service, much lower risk of water damage.
    Just make sure that the return air duct is sealed up well; you don't want it to pull in car exhaust.
    Apr 2006
    Tyler, Tx
    Guys thanks for the responses, i can see two concepts, ease of service vs air distribution.
    Keep the comment coming!
    Which install will provide better comfort?
    Apr 2002
    Quote Originally Posted by amd View Post
    i would be more worried about the furnace casing, the filter slot
    do not blow any air into that garage either
    http://www.ductstrap.com/
    Jun 2001
    DFW
    Explain to "the boss" that the storage space could cost her $100 a month in the summer.
  14. #14
    Apr 2006
    Tyler, Tx
    Quote Originally Posted by paul42 View Post
    'the boss' is a mexican woman, the hardest headed woman of all!
  15. #15
    Tallahassee, FL
    Where the unit is located in your case will not have a drastic effect on comfort. A Variable Speed 2 stage Furnace with 2 Stage cooling will give you the best comfort control technology available. If you are going with a higher end furnace with the variable speed fan motor - - there are thermostats available with built in humidity sensors and dehumidification capabilites built right in. Thats comfort.
  16. #16
    Apr 2006
    Tyler, Tx
    Thats also $$$, which is limited. I am in Texas which means heating is not a priority, would only need to use the furnance like 2 months vs 10 for the AC. I was going with an 80% single stage furnance. Possibly a Payne cuz i can get on the cheap Saddly can't afford the higher end stuff i help make here in Tyler
  17. #17
    burlington county n.j.
    if your going cheap you better put it in the garage so its easy to service and replace.
  18. #18
    Apr 2006
    Tyler, Tx
    But isn't Payne just a Carrier without the bells and whistles?
  19. #19
    Tallahassee, FL
    Quote Originally Posted by artdavila View Post
    I was going to assume it was a Trane!! Is that who you work for?
    Seriously though...if nothing else....upgrade to a variable speed fan furnace....it will conttinue to pay you back in lower cooling bills for the life of the unit. At the least you can have 80% furnace and a single stage cooling with dehumidifation upgrade.
  20. #20
    Tallahassee, FL
    Yes and they have 10 year parts warranty if you register online. So make sure you do this or it will only be 5yr. www.payne.com
    IMO your asking for trouble with a unit named payne!!!!!!
Tags for this Thread
