Results 1 to 7 of 7
Thread: Defrost cycle occurs most often when outdoor temp above freezing & humid???
    Oct 2020
    I would appreciate confirmation of something I was told from a knowledgeable source since it is a little counter-intuitive (at least to me). It is that the defrost cycle occurs most often when outdoor temp is above freezing & there is moisture in the air, particularly on inverter units such as the Carrier 38MBRB/40MBAA. I am considering this unit due to increased 17F btuh output versus non-inverter heat pumps, and was asking how often the defrost cycle may occur overnight at about 20F. The unit uses condenser pipe differential temperature to determine when to defrost. If indeed it will defrost more at higher temp than lower temp (since colder air holds less humidity), it will not have a large impact when trying to get as many btuh's out of the unit as possible on cold evenings.
    Thank you
    Mar 2009
    Mount Holly, NC
    It is all about runtime, and moisture in the air.
    If the ambient is above freezing, but has a lot of moisture in the air… as in, it’s raining, or foggy. IF the heat is running long runtimes, it will need to defrost more often. If however, the heat doesn’t run long runtimes, the warm ambient, and moisture can prevent defrost… it’s all about how tight and well insulated the home and ductwork is.
    The TRUE highest cost system is the system not installed properly...
    Find a HVAC-Talk Contractor by clicking here
    Click below to BECOME a pro member
    https://hvac-talk.com/vbb/forumdispl...ip-Information
    Do you go to a boat repairman with a sinking boat, and tell him to put in a bigger motor when he tells you to fix the holes?
    I am yourmrfixit
  3. Likes Tjune54 liked this post.
  4. #3
    Mar 2018
    Virginia
    If conditions are right, and the coil is developing ice, you can expect about 1 5min. defrost cycle per hour.
    "I think Quantum tunneling would work great... "
    "Call a technician for God's sake. Or we'll see you on the news or the Dark Side of the Moon."
  5. #4
    Jan 2010
    You need to look at the COP (coefficiency of performance)
  6. #5
    And look for a heat pump with demand defrost. Timers should be outlawed.
  7. Likes R600a liked this post.
  8. #6
    Mar 2018
    Virginia
    Yes they should!
    I think the one he’s looking at would be…any higher end unit/good name brand should be
  9. #7
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    We are looking at you payne / bryant / carrier.
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
