Do the new inverter type system eliminate big inrush current?
My 30 year old Lennox should be replaced soon. But it still works!
Anyways. On thing about the old beater is that you cannot run it on a generator. The inrush current is huge.
When I pick out a new A/C, can looking at inverter based ones fix that?
Originally Posted by
badfrogg
Fix I cant answer.
Help Yes.
Inrush is reduced.
However inverter style units tend to be very picky about the cleanliness of the power they receive. Many will need an inverter style generator to function.
“I haven’t failed. I’ve just found 10,000 ways that won’t work.” - Thomas Edison
“It’s not whether you get knocked down, it’s whether you get up.” - Vince Lombardi
Post Likes - 1 Likes, 0 Dislikes
I listened to an episode of HVAC School with Brian Orr that discussed a product to reduce inrush current on systems powered by generators. The title is Hard Start vs. Easy Start. Aug. 25 is the date of the episode.
It sounds like just what is needed in this instance.
Post Likes - 2 Likes, 0 Dislikes
badfrogg
WHAT MFG. ARE YOU or might you pursue ?
You need to contact a local representative in order to obtain SPECIFIC Information on a particular model(s)?
Compare the noted Starting Currents to get an Order- of- Magnitude sense about the limited amount of inrush current.
_ Example: Daikin
https://daikincomfort.com/
Designer Dan __ It's Not Rocket Science, But
It is SCIENCE with
Some Art. _ _
KEEP
IT
SIMPLE &
SINCERE ___ __
www.mysimplifiedhvac.com ___ __ Define the Building Envelope & Perform a Detailed Load Calc: It's ALL About Windows & Make-up Air Requirements. Know Your Equipment Capabilities
