+ Reply to Thread
Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 66
Thread: Walkin freezer puzzle
  1. #41
    Jan 2010
  2. Likes Red850kid liked this post.
  3. #42
    Sep 2016
    PL In New York
    It's close coupled like probably less than 3'
    Go figure.
    Is there water in the vaporizer pan when he's measuring the LL temp before the valve?
    Also when measuring evaporator SH the top panel needs to be in place so air is being forced through the coil.
    Measuring with the top off could give an inaccurate reading.
  4. Likes pecmsg liked this post.
  5. #43
    Sep 2016
    PL In New York
    Looks like a simple unit.
    If it worked before it should work now.
    What about a pump down test to see if the valves are leaking by?
    With no liquid valve how about a compressor performance check?
  6. #44
    Virginia
    Quote Originally Posted by Red850kid View Post
    Package units dont have service valves .... so thats out
    Tell your Cat I said "Psst Psst Psst"
    It seems like everywhere I go the AC is broken
  7. Likes Red850kid liked this post.
  8. #45
    Sep 2014
    How's the insulation on the suction line?
    Is there a suction accumulator before the compressor??
    Insulation is all good. And no accumulator before compressor
  9. #46
    Sep 2014
    Are you sure the condenser is clean? Did you wash it or just blow it out?
    Yes it is very clean I can put my anemometer in from to measure the airflow
  10. #47
    Sep 2016
    PL In New York
    Quote Originally Posted by Snapperhead View Post
    I thought that. What are linesman pliers used for anyhow? Package unit pumpdown tests?
  11. #48
    Sep 2016
    PL In New York
    Quote Originally Posted by Matthonda98 View Post
    Interesting. What were the results?
  12. #49
    Sep 2016
    PL In New York
    Try closing the x valve a half turn. Now what is all your temps and psi's?
  13. #50
    Southold, NY
    There are suction and discharge access valves
  14. #51
    Jan 2010
    Would need the compressor BOM ( Bill Of Materials )
  15. #52
    Jan 2010
    6 X 10 🤔
  16. #53
    Sep 2014
    Go figure.
    No water in pan. And top is on. I’m thinking I evacuate the unit and do a pump down
  17. #54
    Sep 2014
    6 X 10
    Too small of box?
  18. #55
    Jan 2010
    The opposite
    6 x 10 needs at the least 5,000 BTU closer to 6
  19. #56
    Sep 2016
    PL In New York
    Somethings fishy about this thread...
  20. #57
    Sep 2016
    PL In New York
    Yes try evacuating and changing the fd/ adding a MISG.
    Weigh in fresh gas. Did you try adjusting the valve at all?
    Ya know, just to try to get a lower SST?
    How about seeing if the bulb reacts to temperature change(if there is a remote bulb).
    Or to simply see if the valve modulates when adjusted?
  21. #58
    Jan 2010
    Not gonna happen with that condensing unit sorry
  22. #59
    Southold, NY
    If you knew the reading, then that would help but we Don't know so look thru it. You should see clearly through the coil. If you can't wash it out.
  23. #60
    Southold, NY
    Go to the Emerson site and download the performance curve for that pump.
    Or download the Mobil App and run the #'s
    https://climate.emerson.com/en-us/to...es/mobile-apps
  24. Likes trippintl0 liked this post.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
Tags for this Thread
  • You may post new threads
  • You may post replies
