3/4T walkin vs. 2 tons of rotting kale
Church food bank accepted over 200 large boxes of kale, and put in the walkin cooler, >R40 insulation, 8 ft by 16 ft by 8 ft tall with 3/4 T refrig unit, packed pretty solid with kale.
Cooler functioning fine, keeps stuff line 2 tons of milk at 35F with 95F outdoor temps.
Member reported cooler temp 70F inside, so shut off the cooler as only thing in there was kale, but left door closed.
Next morning 95F inside cooler with nightime temp of 55F.
Heat of decomposition overwhelmed the cooler the first day to get to 70F inside, just kept climbing with AC off.
Went to checkout the AC as some suspected the AC failed - working fine, just overwhelmed.
Stuck a thermocouple between a couple of the boxes of kale, 140F!
Suggested church not accept any more 2 ton donations of wilty kale.
Post Likes - 1 Likes, 0 Dislikes
I wonder how many people who go to food donation centers actually eat kale.
Personally I absolutely love kale it makes me best soup ever! But I don't go to food donation centers.
Man I'm hungry I'm going to have to have my wife pick up some kale and russets so I can make my family's traditional kale soup, I have not made it in a long time.
"Is this before or after you fired the parts cannon at it?" - senior tech
I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
Unless we change direction we are likely to end up where we are going.
"It's not new, it's better than new!" Maru.
Originally Posted by
pecmsg
I’m confused
A/C ?
Modified Daikin cool only mini splits if I'm not mistaken.
What the what? Rotting lettuce can get to 140° all on it's own? I never heard of such a thing. Really? Does this soup that R600 likes cook all by it's self? Gross. No thank you.
If at First You Don't Succeed, Skydiving Is Not for You.
ammoniadog
No I use only very fresh kale. Compost is an amazing thing!
ammoniadog
Composting creates heat. 140* seems excessive but, a quick google search says 110*-140* is normal.
Why is it that those who complain the most contribute the least?
MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
ammoniadog
140° is low. There have been cases of farmers bailing hay before it is dried down properly. It can get hot enough to spontaneously combust, otherwise known as catching fire on it's own, out in a field, with bails stacked on each other. If it happens in a barn the barn is gone, can't save it.
R600a
Cool Bot unreliable POS!
They get what they deserve!
pecmsg
Nope it's not a cool bot it's a @junkhound custom cooling solution.
A/C,s are not med temp units!
pecmsg
May not be rated but if it works it works.
R600a
Until they don’t work!
R600a
Kinda like using a flat head screwdriver to remove a phillips head screw.
2sac
A flat head on a torx.
Reason: Stupid autocorrect.
R600a
A flat head on a Robertson eh!
Sent from my SM-G965W using Tapatalk
I prefer a butter knife 😉
pecmsg
I have 4 Restaurants with the Coolbot setups , and those LG window units last about 5-7 years
10x10 boxes
Its crazy
No maintenance other than one Pizza place as a ton of Pollen in the spring , I just hit it with a hose real quick
Tell your Cat I said "Psst Psst Psst"
It seems like everywhere I go the AC is broken
FWIW, the church walk-in Daikin minisplit (FT/RS) does NOT use a coolbot -
Why spend $200 for something that can be accomplished with a 50 cent 22 kohm resistor added across the Daikin RH1 thermistor? Or a few cents more, replace RH1 with different curve thermistor.
So, operating as cooler vs room AC, suction pressure is 100 psi vs. 150 psi, (the Daikin uses R410A)
I'll learn something if anyone has a good technical explanation of why the 150 to 100 psi suction pressure change would decrease total running time operating before failure (AKA MTBF)? The Daikin electronic expansion valve works well into that region.
