Thread: Changing motor speed on Genteq X13 motor
    Aug 2022
    I have a 2011 Genteq ECM motor (X13 FM13) that came from a salvage home unit. It works perfectly but had only one speed tap setup/programmed.
    Is it possible to reprogram the control unit on the motor to provide for more speeds?Name:  IMG_3929.jpg
Size:  2.19 MBName:  IMG_3935.JPG
    Salt Lake City/Tooele
    Simple answer is, no. Complicated answer is to locate a distributor willing to reprogram the module that closely resembles a model with characteristics you desire which is almost an impossibility due to licensing. There is no one I know outside of Genteq Beloit themselves that has custom programmers.
  3. Likes Mr Bill liked this post.
  4. #3
    Jan 2006
    In a land far, far away
    Moved to AOP, this is the section for Homeowners to ask questions.
    Unfortunately, this is a DIY question, and we do not support DIY here.
    Perhaps there's something else we can help you with.
  5. #4
    Houston,Texas
    Quote Originally Posted by tmlanz View Post
    This has nothing to do with the motor itself "can't get into what 1-5 do" this has to do with the air handler, and the way it was designed. Also, these are not speed taps, they are torque taps.
    “Experience is a hard teacher because she gives the test first, the lesson afterwards" ~ Vernon Law
    "It's what you learn after you know it all that counts." ~ John Wooden
    "When the teachers become unteachable we're all in trouble" ~ Mr. Bill
    "Remember "Pro" is only a name, it's not always a mindset determined to do everything correctly" ~ Mr. Bill
