Results 1 to 9 of 9
Thread: heat pump cool only
    Aug 2022
    Question heat pump cool only
    Hi:
    How do I wiring a heat pump to cool only with 2 low volts cable from the air handler
    Southold, NY
    Quote Originally Posted by Pricer Air View Post
    Hi:
    You’d listed as a contractor?
    Virginia
    What Brand is the Outdoor Unit ?
    Most manufacturers energize the "Reversing Valve" on Cooling mode (Rheem & Ruud , maybe Ameristar , energize in "Heat") If the unit has an "O" terminal on the Board it means the Rev Valve energizes in Cooling , so it must get power when AC is needed , and if the unit has "B" means the Rev Valve energizes in Heating which means it wont need power at all, because its already in Cooling mode
    (Although sometimes B can be "common" on older units, so follow your wires to see where they go)
    So if your unit energizes in cooling "O" .... you just wire "O" to come on with "Y"
    We cannot give you any more information about wiring ... that is all you get
    Tell your Cat I said "Psst Psst Psst"
    Virginia
    Dude ... I know 2 contractors who are TERRIBLE when it comes to wiring
    Granted both are Foreigners
    1 called me last week "how do I bypass the door switch"
  5. Likes ksefan, R600a liked this post.
  6. #5
    Mar 2016
    Dayton Oh
    Quote Originally Posted by Snapperhead View Post
    Maybe is resi comfort cooling adopted common wire colors it would be better.
    Did some amistar units (supplied by building owner) and they used purple wire for the w signal. Like really. Purple….
    And they used black wire to the common term where I see most people use blue.
  7. Likes Snapperhead liked this post.
  8. #6
    Hurst11 is offline Professional Member/Membership Committee
    May 2020
    Haskell Oklahoma
    Quote Originally Posted by jbhenergy View Post
    I say make em all black wires and do away with color coding, would force people do pay closer attention to what’s going on. 😂
  9. Likes Snapperhead, R600a, BALloyd liked this post.
  10. #7
    Southold, NY
    Quote Originally Posted by Hurst11 View Post
    and how to use a Meter!
  11. Likes R600a liked this post.
  12. #8
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    White with tiny letters like Carrier used to use.
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
  13. #9
    Mar 2016
    Dayton Oh
    Seen Trane rtus with all black wires and tiny white numbers. Not all the bad really. Find your part in the diagram and then look and see you need wire 423 and 424….
