Results 1 to 15 of 15
Thread: Southbend convection oven issue
    Aug 2022
    I'm working on a Southbend model GS/15SC convection oven that will light and heat up sometimes. Sometimes it has to be cycled of at either thermostat or on/off switch to light. This happens at startup as well as when thermostat satisfies. The unit has a new thermostat control board, temperature sensor, ignition control and ignitor. Any help please, it's becoming a real mystery.
    Virginia
    is the ground pin broke off the plug end ...
    Tell your Cat I said "Psst Psst Psst"
  3. Likes Restaurant mech liked this post.
  4. #3
    Jan 2020
    Winnipeg Canada
    Along with the ground issues, I've had failing capacitors on convection ovens go intermittent.
    And there just aren't enough hours in a day to stand there and wait for the bugger to fault.
  5. #4
    Jan 2010
    Pilot flame size ?
  6. #5
    Virginia
    Quote Originally Posted by Restaurant mech View Post
    I hate babysitting Ice Makers
  7. #6
    Aug 2022
    I will check on the ground, thanks. As far as pilot flame when it lights, pilot and main burner flame are fine.
  8. #7
    Jan 2010
    Is the pilot flame drifting off the sensor ?
  9. #8
    Oct 2008
    Quote Originally Posted by BoB69 View Post
    So you replaced all those parts? For what reason? Are you completely refurbishing this oven? If so, then you should replace a bevy of other parts also...just to be sure.
    If NOT, and all you're doing is changing parts to fix "A PROBLEM", then the cost for all those parts you have replaced ($four figures) likely surpasses the cost of calling a qualified technician to repair it in the first place.
    By the way: You said you checked the pilot flame. Well...that oven doesn't HAVE a pilot.
    Here's some questions you need to answer:
    • What did you find during your initial, thorough visual inspection of the in-shot burners, associated components and wiring?
    • What gas pressures did you read coming in and leaving the gas valve?
    • Is the ignition module being energized upon each and every call for heat?
    • What are the diagnostic LEDs telling you on that new ignition module?
    • When the in-shot burners lights, does the initial right-hand burner flames properly cascade across all other burners and completely over far left burner?
    • If so, then what flame current did you read?
    The answers you get from my questions above will likely lead you to find the one single thing that was causing your problem the whole time.
    So there's no need to post any answers to those questions. Since this is NOT a DIY forum, I've probably said too much as it is.
  10. Dislikes BoB69 disliked this post.
  11. #9
    Apr 2022
    Northeast US
    You say this happens sometimes, these ovens are super sensitive to air flow entering the combustion area, the front panel needs to be in place correctly. The sense rods seldom go bad, however, you should attempt a micro-amp reading, sometimes just rubbing them clean with plumber's cloth will rejuvenate them. Because attempting a light with the front panel off introduces enough air to stop the burner bar from carrying the ignition across, all test attempts will only work blindly. With the natural gas units, check your line manifold, natural is pretty sensitive to load fluctuations of all equipment operating on the cook line, the fryer right next to it may be starving it of enough pressure to maintain it's operation.
  12. #10
    Aug 2022
    Checked and ground was present. Found problem to be microswitch on rear solenoid is not opening and closing every time. Thanks for your help.
  13. Likes Bob-Brr liked this post.
  14. #11
    Virginia
    Oh dam .... so it just needed a little adjusting ?
  15. Likes ECtofix liked this post.
  16. #12
    Oct 2008
    WELP. I am happy that you solved it, but I am now confused.
    Categorically speaking, there are only TWO micro-switches in that oven.
    • One for the oven's cooking compartment door
    • And...(unique to Southbend), one for when the control panel is pulled out to serve as a safety SHUT DOWN switch (like gas furnaces have).
    There is NO solenoid in that oven. At ALL.
    However, there is a solenoid VALVE, but one which is most commonly referred to in our trade as a COMBINATION VALVE. This oven uses a standard 24v Honeywell one designed for direct spark (or HSI) ignition (only has MV terminals. No PV terminals).
    I can't think of any...and I mean ANY scenario in that oven where a solenoid (valve) and a micro-switch have anything AT ALL to do with each other.
    I state all this merely for any future-referencers happening through here seeking some eduvacation to solve their own Southbend oven's woes.
    FWIW: Most DIYers are generally already finding themselves "standing in left field with a hockey stick while waiting for the kickoff".
    That's a bad start.
    Nonetheless, they wanna save a buck by fixing it themselves, but don't even know any basic troubleshooting practices, much less what a VOM or a manometer is.
    So they throw a bunch of new parts in it, which quickly gets...EXPENSIVE.
    Pursuing a fix by replacing parts is like throwing money into a trashcan... while actually NOT fixing ANYTHING. It also increases the down time of the appliance while needlessly diddle-daddling around installing shiny new parts.
    SO...FOLKS! Save yourself some grief and some money by just CALLING A SERVICE COMPANY.
    You'll get it done quicker and (probably) cheaper....unless you get LUCKY.
  17. Likes Snapperhead liked this post.
  18. #13
    Oct 2008
    Quote Originally Posted by Snapperhead View Post
  19. Likes Snapperhead liked this post.
  20. #14
    Jan 2010
    Preventative maintenance 😃
  21. Likes ECtofix, Snapperhead liked this post.
  22. #15
    Virginia
    Preventative maintenance ��
    He should have a slew of spare parts incase of emergencies ...
  23. Likes ECtofix liked this post.
