Results 1 to 16 of 16
Thread: True Electronic temp control board.
    Aug 2022
    I don't really work on refrigeration units but work said so. So we have a gdm-49f that will not go into defrost. I can manually do it but I have no voltage going to the defrost heaters. And yes I waited for time dely. Heaters draw 7 amps when jumped to line.
    Anything else I can check before ordering a $ board.
    Oct 2011
    Chicagoland Area
    Muddbutt? Is that like swampass?
    Why is it that those who complain the most contribute the least?
    MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
    Aug 2022
    I'll pay 12 dollars to shoot you please.
    Southold, NY
    Quote Originally Posted by Muddbutt69 View Post
    Anything else I can check before ordering a 500 dollar board.
    No voltage but 7 amps, how’s that possible?
    Apr 2022
    Northeast US
    No voltage going to heaters, but, 7 amps when he jumped out the control.
    Bad control board, some of those have controllers and a separate relay board, still, True charges a fortune for their junk.
    On a bull named Foo Manchu
    Is the defrost light on when checking?
    The dot next to icon not " def "
    Jun 2009
    DFW, TX
    Have you confirmed the coil sensor is not reading warmer than the defrost termination temperature?
    Sent from my SM-G892A using Tapatalk
    Aug 2022
    Yea.
    Aug 2022
    Wouldn't a manual defrost override this? I did not check.
    Aug 2022
    Quote Originally Posted by trippintl0 View Post
    Wouldn't a manual defrost override this? How do I check this.
    No
    If the dot is on the heater relay should be on
  13. Likes Bob-Brr liked this post.
  14. #13
    Apr 2022
    Northeast US
    No
    They probably didn't use a relay. so the board is handling full loads, hence the burnt board.
  15. #14
    I was referring to the relay on the board
  16. Likes Bob-Brr liked this post.
  17. #15
    Mar 2013
    swan valley idaho
    Cold control, paragon clock. Done
  18. Likes Bob-Brr liked this post.
  19. #16
    Removed the price, as prices aren't allowed here.
