Results 1 to 20 of 39
Thread: Retirement and the full time RV lifestyle
    anywhere my RV is
    well, kids, its been awhile since I posted here.
    I retired last year, SOLD EVERYTHING, business, home, tools, everything, and bought an RV and we have been living the nomad lifestyle, and its been a blast. We named her the Escape Pod, Because we escaped New Yorkistan
    Last Sept we left Rochester, NY, went to Fredericksburg Va, then to Knoxville, Tn, then to Moss Point ms, and rt-10 to Phoenix Az by January 3rd.
    In Phoenix we picked up a 2000 Jeep wrangler, installed 1500W of solar and 606Ah of Lithium batteries so we can boondock in the wilderness and still have power to run the entire Escape Pod. All we need is food and water. We can stay out in the wilderness for a month or more, before we need to resupply
    But in Yuma, I ran into a interesting (on going) issue. The a/c's are controlled by a Thermistor(s) But they are so far off calibration it's ridiculous. I have no idea what voltage these thing have? but I would like to switch to a standard, cheap ass, snap action thermostat
    Do any of you know how a thermistor works, I don't have clue, or what voltage they may be at? Thor is not very forthcoming with information.
    This is a Thor Magnitude XG32, Ford F550 4x4, with a 6.7L turbo diesel
    The truth has no defense against a fool
    Determined to believe the lie
    Mark Twain
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    What brand is the AC?
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
    Jul 2020
    Lincoln Nebraska
    Thermistors are notoriously sensitive to moisture, it causes the majority of thermistor failures. Even the epoxy coated kind are prone to fail if kept wet. Their resistance changes as a function of temperature. The R vs T curve varies significantly dependent upon the mfgr & particular model. A degree or two off isn't excessive in this application, but 12°F is way off. I would bet there is are variables hidden somewhere in the thermostat to zero and span the sensors, but maybe not accessible to the user.
  4. Likes Scoobie, jmac00 liked this post.
  5. #4
    Oct 2016
    Can’t help with your thermistors….but congrats on living your dream! Man that sounds awesome. Enjoy your rambling.
  6. Likes jmac00, 2sac, ksefan, joemach liked this post.
  7. #5
    Apr 2020
    Garner NC
    I got this, lol…when I traveled to disaster site’s rebuilding homes backed by multi millionaire and multi billionaire investors..I had my 1994 fleet wood bounder 34j I had 2 AC units on it…my propane gas heat failed one time due to a bad diode and easily replaceable…
    Here ya go..through DDG web search…you will see pics of different thermistors (temperature sensors) and other links..
    https://duckduckgo.com/?q=rv+thermistor&t=iphone&ia=web
    Your RV should have come with a very thick book of every item in it with the manuals..
  8. #6
    anywhere my RV is
    Quote Originally Posted by R600a View Post
    Coleman, Mach.....
    Mark Twain
  9. #7
    anywhere my RV is
    I guess the only thing to do is trace these things back to the unit and see what the voltage is, and then finding a stat that will work.
    Mark Twain
  10. #8
    R600a's Avatar
    Jul 2019
    Quote Originally Posted by jmac00 View Post
    Coleman, Mach.....
    Who knows what they've come out with since I swore off RV repair but last time I worked on RVs all the Coleman's were 12 volt control as far as I knew. I always figured if I had one I would throw in a 24 volt transformer down in one of the compartments where there was 110 volts available and run it up to a regular thermostat and feed those wires down to a relay panel I would build to convert my 24 volt signals from my nice Honeywell thermostat to 12 volt for the RV air conditioner. That or gut the controls of the unit and put my relay panel up there controlling the loads directly.
  11. #9
    Oct 2016
    I think you will struggle putting a normal stat on and getting it to work. Those rev units are kind of unique. I would ohm out the thingys. Maybe get some new thermistors.
  12. #10
    R600a's Avatar
    Jul 2019
    If you want to know how the factory controls work I can get you the service manual from my buddy who owns an RV store if you send me a picture of the data plate.
  13. Likes rundawg, Scoobie liked this post.
  14. #11
    anywhere my RV is
    we are having a blast, been all over Arizona, from Yuma, to Grand Canyon. We went to Las Vegas ( absolutely hated it ) Hoover dam, Valley of Fire. Diesel prices have slowed us down a little, but not much, we are members of Harvest Host and Boondockers Welcome. we can camp for free or next to nothing.
    Mark Twain
  15. Likes Scoobie, ksefan liked this post.
  16. #12
    anywhere my RV is
    cool, I'll get up there tomorrow and get that info
    Mark Twain
  17. #13
    R600a's Avatar
    Jul 2019
    I think it's usually under the cover on the ceiling inside the rv but like I said I quit working on them a few years ago because I found that I lost too much money working on rvs so I could be remembering wrong.
  18. Likes jmac00 liked this post.
  19. #14
    Oct 2013
    MA
    Have you checked the temperature near each thermistor? They aren't in that touchscreen - they will be separately mounted in the front and back of the RV, one for each unit. That way you can see if there's an external influence throwing them off.
  20. Likes R600a liked this post.
  21. #15
    Apr 2020
    Garner NC
    You will be correct R600…that’s where they was located in mine when I had it, there was an opening in the inside cover so it could read it..at the ceiling in the unit…hot air rises and that’s where it’s reading from …
    A temp probe at the ceiling should show the same reading
    However on some of these newer units the indoor sensor could be anywhere remotely and strategically placed…
    This is an example …don’t know if it’s the correct model but it is a Coleman Mach..
    http://old.rvcomfort.com/pdf_documents/1976342.pdf
  22. Likes R600a liked this post.
  23. #16
    R600a's Avatar
    Jul 2019
    Quote Originally Posted by Unlimited1 View Post
    I was actually talking about the data tag.
  24. Likes Unlimited1, jmac00 liked this post.
  25. #17
    anywhere my RV is
    sorry, I got a really bad head cold, and allergies are kicking my ass, I'll get on this tomorrow. My apologies
    Mark Twain
  26. Likes R600a liked this post.
  27. #18
    Jun 2022
    Michigan
    Thermistor’s are basically variable resistors and either have a positive or negative temperature coefficient. If you can get at the thermistor you should be able to find out a part number and get the nominal value and slope and diagnose if it is bad or not. Then you might be able to use a snap action thermostat with a resistor in series to fool the control unit.
  28. Likes R600a, jmac00 liked this post.
  29. #19
    Mar 2015
    Tx
    Get signed on the Escapees, Rvforum, Rvnet, etc forums & do some search on the touchscreen controllers. Lots of unhappy campers with these single point control of everything. Also lots of these are fixed with an update of software.
    AirExell is the owner of the Coleman Mach AC's now.
  30. Likes R600a liked this post.
  31. #20
    Houston,Texas
    Isn't a Thermistor the same gadget you stick into an evaporator, that has an issue freezing up?
    “Experience is a hard teacher because she gives the test first, the lesson afterwards" ~ Vernon Law
    "It's what you learn after you know it all that counts." ~ John Wooden
    "When the teachers become unteachable we're all in trouble" ~ Mr. Bill
    "Remember "Pro" is only a name, it's not always a mindset determined to do everything correctly" ~ Mr. Bill
