Thread: Rheem R802VA075317MSA
    Aug 2022
    Hello:
    My Rheem furnace is not blowing out enough air through any of the vents. I noticed that you can adjust the speed for heating and cooling with the dip switches. Question is what dip switch do I turn on to increase the airflow?
    Also I noticed that this furance has a filter on the left side and a filter on the backside. I have also a mechanical filter system attached and regularly change that filter but I have never changed the filters on the furnace cabinet itself. Thanks for your advice.
    Southold, NY
    You meeed a static pressure test before changing anything!
    Jun 2014
    Dover, DE
    What’s your definition of not enough?
    Ideally you shouldn’t feel or hear the airflow.
    Not changing filters isn’t a good idea.
    “I haven’t failed. I’ve just found 10,000 ways that won’t work.” - Thomas Edison
    “It’s not whether you get knocked down, it’s whether you get up.” - Vince Lombardi
    Philadelphia, PA
    What do you mean when you say there is a filter on the side and on the back?
