Results 1 to 9 of 9
Thread: Ruud vs Ameristar (limited availability of other options) - Florida
    Jun 2009
    Hi All,
    1700 SF Rental house - limited options for availability to get tenants cooled. Northwest Florida.
    Condenser unit, only. Was dual fuel, but we are retaining the Carrier gas furnace.
    No availability of Carrier, Goodman, or American Standard.
    Options:
    - Ameristar (80% cheaper than Ruud)
    - Ruud
    I have usual gone with Ruud when close - thoughts?
    Thanks.
    VA
    Ameristar used to be made by Midea made in China. Trane/Am Std has switch to production to the US with the Ameristar and RunTru line. Basically it's Trane's budget line. I've installed a few and didn't see any issues with them. The Midea Ameristar units are now called Ox Box. They are still made in China I believe.
    They're definitely built cheaper than the Trane/ AmStd, but they work fine. They're pretty simple, sometimes simple is good when it comes to this industry. The one RUUD I've installed had a defrost control board failure about a year after installation. It was a known issue as they have since changed the board configuration. Other than that, "knock on wood", no issues with that one either. Quality wise, I would say the RUUD is a little nicer looking, but I don't have much history with them. The Chinese made OxBox use cheaper components, but their quality control is superior to the US built equipment.
    "The only true wisdom is in knowing you know nothing" Socrates
    Jun 2009
    I think I'm gonna go with Ameristar - the 20% difference in price is pretty meaningful if they are generally close in performance/warranty.
    Jan 2010
    Did he type "80% cheaper" than Ruud ?
  5. Likes Mr Bill liked this post.
  6. #5
    Houston,Texas
    Does that Ameristar have the LG compressor? and probably has the PSC fan, but for a rental, go for it.
    “Experience is a hard teacher because she gives the test first, the lesson afterwards" ~ Vernon Law
    "It's what you learn after you know it all that counts." ~ John Wooden
    "When the teachers become unteachable we're all in trouble" ~ Mr. Bill
    "Remember "Pro" is only a name, it's not always a mindset determined to do everything correctly" ~ Mr. Bill
  7. #6
    Jun 2009
    No - was avoiding numbers since site says to do that - my approx math between the two prices.
  8. #7
    Jan 2020
    Winnipeg Canada
    I switched to run tru Ameristar....
    Honestly for the price.... they are the best builder grade units out there.
    High and low pressure safeties, spine fin coil.
    Perfect for a rental.
    I choose them above Goodman
  9. #8
    Jun 2009
    Quote Originally Posted by Restaurant mech View Post
    The HVAC tech/owner mentioned the spine fin coil, as well!
  10. #9
    Jan 2020
    Winnipeg Canada
    Quote Originally Posted by stephenson View Post
    Yeah the spine fin is truly awesome in MOST respects. They tend to run better dirty than a tube/fin runs clean.
    However, IF it develops a leak it's likely toast. I used to install trane spine fins in those places that don't get proper maintenance/ cleaning.
    Now with the run tru I install them everywhere.
