Results 1 to 20 of 23
Thread: NEW HERE NEED HELP WITH SHORT PROBLEM ON AIR HANDLER
    Aug 2022
    PSL, FL
    Lightbulb NEW HERE NEED HELP WITH SHORT PROBLEM ON AIR HANDLER
    Hello,
    New here. Thomas from Florida. I was installing new thermostat and caused a short while doing it as I forget to turn off the power wiring. I didn't have a breaker in the line on the R so I replaced the transformer (and put in breaker relay in the line) since it didn't hold current on the 24v side and replaced the fan relay as well. I also installed new run capacitor since my unit is a RUDD 18 year old air handler with no board (all collectively costing me less than dollars for all OEM Ruud parts). I can jump the red with the yellow at the thermostat site and shoots out cold air and same with red and white with heat but when I do it with red and green (fan) it shorts and pops my inline breaker. I tried switching to the blue line in the thermostat wires to rule out if it was a bad green wire but it still shorts with the green to the air handler. Seeing if this is just wiring needing to be replaced as this air handler is pretty simple. Just can not find this short when green and red jump. Any help would be appreciated as I'm about to just replace the green wire throughout.
    Jan 2006
    In a land far, far away
    Moved to AOP, this is the homeowner section. Please note new location.
    Also removed pricing, that is not allowed per site rules.
  3. Likes tjglock liked this post.
  4. #3
    Southold, NY
    That’s a lot of parts. Maybe call someone qualified?
  5. Likes kdean1 liked this post.
  6. #4
    Cincinnati, Oh
    Did you try replacing the evaporator coil?
  7. Likes BBeerme, kdean1, HVAC_Marc, BALloyd liked this post.
  8. #5
    Aug 2009
    Beatrice, NE
    I read where you shorted the control wires, I didn't read where you tested to see what if anything was damaged. Then I read where you replaced a bunch of cheap parts, which from reading your account is where the short started.
    You say that R-Y shoots out cold air but R-G kicks the breaker. R-Y should kick out no cold air as the blower is not energized through Y.
    It sounds like you need someone to go through all your wiring to see where things went wrong.
  9. #6
    Houston,Texas
    Quote Originally Posted by hvacvegas View Post
    Hey! no DIY advice here. Name:  image023.gif
    “Experience is a hard teacher because she gives the test first, the lesson afterwards" ~ Vernon Law
    "It's what you learn after you know it all that counts." ~ John Wooden
    "When the teachers become unteachable we're all in trouble" ~ Mr. Bill
    "Remember "Pro" is only a name, it's not always a mindset determined to do everything correctly" ~ Mr. Bill
  10. Likes 2sac, vin lashon, kdean1, VTP99, BALloyd liked this post.
  11. #7
    Oct 2002
    Plano, TX
    Pull all the low voltage wires off. Rewire like schematic shows. Except stat Check operation at stat subbase. Then add the NEST "c" wire adapter back. This is simple
  12. #8
    Oct 2011
    Chicagoland Area
    Where's the water on the right side of the cabinet coming from?
    Why is it that those who complain the most contribute the least?
    MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
  13. #9
    Southold, NY
    Quote Originally Posted by 2sac View Post
    Condensation 😇
  14. #10
    Virginia
    You seem to be electrical educated ....
    Get a Short Pro Tool
    https://www.globalthesource.com/prod...short-pro-tool
    (Shop around for it , prices will be all over the place)
    You pull the 24v fuse , alligator clip this Tool in its place ... if everything is fine , the unit will run ... and if there is a short the Blue LED will light up
    Remove wires until the Blue LED goes out .... now you know where your short is , and when the sort is fixed the light will go out
    Tell your Cat I said "Psst Psst Psst"
  15. #11
    May 2014
    Bay Area California
    I heard they stopped making those. Even if the photo shows a Short-Pro-Tool, they will ship a 3A breaker.
    If you want a real short pro tool, need to contact R-600, he makes them.
    Quote Originally Posted by Snapperhead View Post
    I do a triple evac with nitro to remove non condensables.
    I'm feelin' a little peculiar.
  16. Likes STEVEusaPA liked this post.
  17. #12
    Jan 2006
    Pros - Le's be careful of the DIY advice, please.
  18. Likes vin lashon liked this post.
  19. #13
    May 2014
    Bay Area California
    Oooopsie
  20. #14
    Cincinnati, Oh
    I still say evaporator coil.
  21. Likes kdean1 liked this post.
  22. #15
  23. Likes kdean1 liked this post.
  24. #16
    Virginia
    Those pesky evaps are definitely a pain nowadays .... but that may not be the issue ... this time
  25. #17
    Mar 2009
    Mount Holly, NC
    I'm sorry, but diy advice is against the rules here. Best we can do is suggest you call a tech capable of determining the fault.
    Far less expensive than swapping parts, or breaking things
  26. #18
    Salt Lake City/Tooele
    Maybe you guys know? WTH is that weird white contraption mangled amongst the wiring carnage there?
  27. #19
    Athens, Ohio
    Quote Originally Posted by slctech View Post
    That’s a device added to some thermostat kits so the HO can further screw up the wiring.
    Site member map HERE!
  28. Likes BBeerme, 2sac, Mr Bill, hvacvegas liked this post.
  29. #20
    Quote Originally Posted by kdean1 View Post
    It is an "Add-a-Wire" or whatever each mfr wants to call it.
    Allows the need of 5 wires to be operable with only 4.
Tags for this Thread
