Results 21 to 32 of 32
Thread: It Never Freaking Occurred to Me to Think...
  1. #21
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    Quote Originally Posted by billygoat22 View Post
    put a piece wood behind the sofa leg so it wont slide to the wall and tear it up.
    While you are at it put one behind the fridge to maintain the required 2" clearance.
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
  2. #22
    Mar 2016
    Dayton Oh
    Quote Originally Posted by ammoniadog View Post
    They did. It's called not sanding the pipe and brazing with 15% silfoss.
    I was actually taught it was good practice to sand even if brazing… just saying
  3. Likes R600a, pacnw, Jim5418 liked this post.
  4. #23
    Mar 2013
    East Concord, NY
    Quote Originally Posted by ksefan View Post
    So you pulled your vac through the side port with the valve core?
    yes, except I pulled the cores from the side ports
    Nest is POO!!
  5. #24
    in a house, Appomattox, Va.
    speaking of appliances, range manufacturers need to get their heads screwed back on straight. every one I see has the bumpouts in a different spot in back, so evrytime you get a new stove, have to move the plug or it wont go back to wall.
    Col 3:23
  6. Likes R600a liked this post.
  7. #25
    Quote Originally Posted by HVAC_Marc View Post
    How do you check micron/vacuum level?
  8. Likes R600a liked this post.
  9. #26
    The thing I see a lot- everyone that comes to your house doesnt know where you put the house number, so dont be creative. by the front door or the mailbox, period. in the bushes, roof, out in yard I wont see in the 1 sec it takes to pass your house.
    put the number on both sides your mailbox, people come from either direction. 1" number size for each 10 mph on the street speed limit. again, I'm not standing 2' from the mailbox like you were when you put the number on it.
    X2
    Worst yet, nothing to be found and out in the country with no cell service so you can't even call to confirm which driveway to pull into.
    Anytime this happens I make sure to mention it sternly to the customer or the wrong house occupants when it get there.
    "I think you have the wrong house."
    "If there was an address anywhere visible, I wouldn't be now would I?"
    Or
    "Sure would make things easier on me or an emergency vehicle if you had an address somewhere!"
    And make sure the numbers on the house are able to be seen color wise, too. Black numbers on a brown house or brass numbers on a yellow house, etc.
  10. Likes R600a, billygoat22 liked this post.
  11. #27
    commented to coworker one time, why do cans with the pop top lids say on side, can use can opener other end? why do the pop top then?
    he said, people with arthritis cant work the tab, so have to use elec can opener regardless.
    Col 3:23
  12. Likes R600a liked this post.
  13. #28
    yes, I have a flashlight....
    Col 3:23
  14. Likes 406Tinner liked this post.
  15. #29
    Jul 2019
    Montana
    Thank you, I get soooo irate (is that how you spell that?) When I cannot read the gatdamn house number! Like MFers why
  16. Likes R600a liked this post.
  17. #30
    did that today, 306 main st, but there's a south and a north main. hardly any building numbers on main st either end. was suite c, door is on side of building that has a giant sign on front for anotjer5 business, but no indication that there any other businesses in building from front.
    Col 3:23
  18. #31
    Mar 2013
    East Concord, NY
    Quote Originally Posted by pacnw View Post
    On a different port.
    Nest is POO!!
  19. #32
    Dec 2020
    Overland Park, Kansas
    I just might be the only one who did’t already know this by now but maybe not. Go slow with drill bits when drilling think metal. I went through so many bits over the years it’s embarrassing. I just figured they only last a few holes on the tough stuff. I did always use the oil but i was always using high speed on drill. I went through 5 of my 6 drill bits working with stainless plate last year, did some google learning and finished 10 more holes with last bit.
  20. Likes HVAC_Marc liked this post.
