Need help: How to balancing the cooled water chiller system in Datacenter?
The cooled water chiller system in Datacenter has 2 risers (2 water chiller supply pipes and 2 water chiller return pipes)
Does anyone have a document about balancing the cooled water chiller system in Datacenter?
Please help me!!!
Many thank!
So much is missing from this...we use chiller Differential Pressures measured in FEET to determine flow at the chillers (or circuit setters)
You need the job drawings/ mechanical/specs.
- You may not post replies
- You may not edit your posts
Forum Rules
