+ Reply to Thread
Results 1 to 20 of 26
Thread: Gas pipe soft solder.... yeah Colombia
    Jun 2019
    Just on some holidays.... and see this actually. You think it will leak LOL?
    Another country, another code... or should I say habits?
  2. Likes R600a liked this post.
  3. #2
    Mar 2016
    Dayton Oh
    Curious why it would leak?
    Gas lines in residential neighborhoods around me are like 10psi or less.
    Or is there something in gas that will eat away the solder?
  4. Likes R600a liked this post.
  5. #3
    Aug 2001
    Pavilion, NY
    I think the concern here is when repairing damage or adding a runout, a torch would be necessary on a line that has gas in it. Recipe for disaster to the untrained person
  6. #4
    Jun 2019
    Quote Originally Posted by jbhenergy View Post
    seismic zone, building may move and then eventually put tension onto pipes... just my though. Usually we do not soft solder gas pipes because if there is a fire... much longer time to go until brazed lines leak
  7. Likes kangaroogod liked this post.
  8. #5
    Cincinnati, Oh
    Quote Originally Posted by gustavhorna View Post
    That would be my thought.
    For instance, the reason you can use a street 90 in gas, has to do with it not having a high enough tensil strength.
    I’ve heard in California, all appliances shall have a piece of flex on it for this reason.
  9. #6
    Mar 2013
    East Concord, NY
    Ive done worse (in my own house 25 years ago). And that house is still standing.
    Nest is POO!!
  10. Likes R600a liked this post.
  11. #7
    north suburbs of Chicago
    Quote Originally Posted by hvacvegas View Post
    Do I have this right? You can't use a street el on gas? Are you talking about black pipe els? On the copper I always thought solder had more to do with a house fire. I have never understood running copper for gas lines. Every time I have dismantled a copper gas line I can shake out loads of this loose stuff in the lines that look like graphite flake.
  12. #8
    Cincinnati, Oh
    Quote Originally Posted by Glennhvac View Post
    5.14 international fuel gas code.
    No shoulderless nipples, street fittings in black iron.
    In gas.
    Hydronic piping is fine.
  13. Likes Glennhvac, kangaroogod liked this post.
  14. #9
    Mar 2016
    Dayton Oh
    In gas.
    Yet not a single inspector will ding it…..
  15. Likes R600a, HVAC_Marc liked this post.
  16. #10
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    In gas.
    What is a shoulderless nipple or a shouldered nipple for that matter?
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
  17. #11
    Cincinnati, Oh
    Quote Originally Posted by R600a View Post
    https://www.lowes.com/pd/Sigma-Elect...tting/50209905
    That’s for galvanized, but you get the drift.
    It’s a black iron nipple that is all threads, not uncut pipe in the middle, or shoulder.
  18. Likes R600a liked this post.
  19. #12
    Cincinnati, Oh
    Depends on your market.
    Joe munde, Steve Osage, Gary berling in Cincy would hit you on them every time.
    Reggie, use to pass out stickers for guys to put on furnaces.
  20. Likes R600a liked this post.
  21. #13
    Mar 2016
    Dayton Oh
    The two dayton inspectors are let’s say……
    Ted who does the commercial inspections is a bit better at actually spotting violations.
    I went through a whole back and forth with dayton over spray foam insulation for ductwork in attic. Inspector came out and didn’t even mention it….
    County is hit or miss, depends on the day of the week…..
  22. Likes R600a liked this post.
  23. #14
    Wow! In 45 years I must have a few thousand violations when you factor in close nipples. Thinking about it I can see that the pipe wall thickness is pretty thin.
  24. Likes R600a liked this post.
  25. #15
    Mar 2016
    Dayton Oh
    Me too
  26. Likes R600a liked this post.
  27. #16
    R600a's Avatar
    Jul 2019
    Between close nipples and street 90s I am toast.
  28. Likes Glennhvac, HVAC_Marc, dieseldude liked this post.
  29. #17
    Cincinnati, Oh
    I’m not absolutely sure about this, but:
    I believe that left/right nipples in gas are also banned.
    A left right is a nipple that with you spin clockwise, it tightens in both directions.
    One side of the threads is actually in reverse.
    A special left right coupler is needed with it.
    It’s purpose is so that you can cut out a section of pipe, and not have to use a union.
    As far as street 90, there are applications in gas that supersede IFGC.
    Goodman GMH is a specific example. The installation manual said for right entry, to use a street 90, a 3in long nipple, and a 90.
  30. #18
    Aug 2001
    Pavilion, NY
    Close nipple standard 90° all day for me
  31. #19
    Jan 2010
    Sea to Sky
    Also any reducing bushing less than a 2 size difference shall be steel, not black iron.
    Ie. 1/2" to 1/4" is ok as black iron. 1"2" to 3/8" cannot be black iron...must be steel.
    Sent from my SM-G965W using Tapatalk
  32. #20
    Northern Calif
    my uncle was remolding his kitchen , he needed to move the water heater temporarily, he used sch 40 PVC for the natural gas line. the inspector didn't like that, and sent the local gas company over to red tag the house, until he replaced it with black pipe.
    I'm not young enough, to know everything...
  33. Likes R600a liked this post.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
