Results 1 to 20 of 32
Thread: Blue hose
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    Blue hose
    I am finally set up for dual hose evacuation! I am testing it out on my bosses van.
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
  2. Likes JayMan7, kdean1, dieseldude liked this post.
  3. #2
    Feb 2018
    Bay Area, Ca
    Quote Originally Posted by R600a View Post
    Yeah boi!!! Lol. I just got a barely used 10cfm jb pump for $160. The guy bought it to pull bubbles out of epoxy and realized it wouldn't work... his loss my gain. And I got a free imanifold from jmart that I have yet to use... they have the probes for me but I haven't been back yet to get them.
    DTOM
  4. #3
    R600a's Avatar
    Jul 2019
    Quote Originally Posted by Zamoramax View Post
    DTOM
    Ironically hooking up the second hose takes more time on a residential system install than it saves but on stuff like residential refrigerators it'll save me a ton of time.
  5. #4
    Mar 2018
    Virginia
    I use 2 - 1/2” hoses and I don’t think I’ll ever go back!
    "I think Quantum tunneling would work great... "
    "Call a technician for God's sake. Or we'll see you on the news or the Dark Side of the Moon."
  6. Likes Zamoramax liked this post.
  7. #5
    Feb 2018
    Bay Area, Ca
    Quote Originally Posted by JayMan7 View Post
    Yup. Im itching to go head to head with my 7 and 10 to see if there's a difference. Im going to guess its negligible.
    DTOM
  8. Likes R600a, JayMan7, dieseldude liked this post.
  9. #6
    R600a's Avatar
    Jul 2019
    My hoses are bigger than your hoses.
  10. #7
    R600a's Avatar
    Jul 2019
    Now I just need to convert my pump to KF flanges.
  11. #8
    Mar 2018
    Virginia
    IDK they’re big BLACK hoses…once you go black you can’t go back
    But seriously lol..what’s the ID on those blue ones you got?
  12. Likes Zamoramax liked this post.
  13. #9
    R600a's Avatar
    Jul 2019
    3/4".
  14. Likes Zamoramax liked this post.
  15. #10
    Mar 2018
    Virginia
    3/4".
    Damn now I feel like a loser lol
  16. Likes dieseldude liked this post.
  17. #11
    R600a's Avatar
    Jul 2019
    This is my true blue mess.
  18. Likes JayMan7, dieseldude liked this post.
  19. #12
    R600a's Avatar
    Jul 2019
    Well I pulled the truck down to 135 microns although I didn't do a decay test so it probably was not really truly below 200 microns and charged it up and found the cause of the failure there's only 9 volts to the clutch so looks like I'm going to be adding a relay and a direct line from the battery.
  20. #13
    VA
    Trash all over the dash…
    "The only true wisdom is in knowing you know nothing" Socrates
  21. #14
    R600a's Avatar
    Jul 2019
    Quote Originally Posted by mgenius33 View Post
    Yep. It's almost a company trademark.
    Where else do you store all the invoices until tax time?
  22. #15
    Mar 2018
    Virginia
    Oh no…did they really bury the clutch relay under the dash?
  23. #16
    R600a's Avatar
    Jul 2019
    I will try replacing that first but often there is too many connections and undersized wire that had deteriorated over the 21 years of slamming down the road on Fords joke of a suspension system so the resistance is just too high.
  24. #17
    Jan 2010
    Don't forget to add a in line fuse 😉
  25. Likes R600a, dieseldude liked this post.
  26. #18
    R600a's Avatar
    Jul 2019
    For sure
    My 16-year-old brother-in-law did quite a bit of mechanic work for the last few years and he repeatedly fixed vehicles for this one local idiot firefighter who kept doing things like installing aftermarket lights and radios with no fuses and then getting a short and melting everything.
  27. #19
    R600a's Avatar
    Jul 2019
    I'm feeling like a bit of a dummy I was so focused on the AC system I didn't notice that the alternator was bad. Looks like I won't have to mess with the AC wiring.
    Pretty crazy that an alternator going out could wipe out the AC clutch that fast.
  28. Likes JayMan7, Zamoramax liked this post.
  29. #20
    Chicago area
    DTOM
    Depends on what your doing. Small oil free new lines and coil. Take longer to run the power cord and set up the pump.
    On a larger system, your looking at significant time savings if you have big enough hoses. Not a big deal if your running over night and returning to the job next day, but a huge savior if your babysitting the pumps on an emergency repair.
  30. Likes dieseldude, VTP99, Zamoramax, R600a liked this post.
