Results 1 to 9 of 9
Thread: High and low side are 25
    Jun 2022
    Checking g out unit both high
    Southold, NY
    Quote Originally Posted by Ale246 View Post
    OK if you say so.
    A little more information would help!
  3. Likes dieseldude, 2sac liked this post.
  4. #3
    Jun 2022
    Both high side and low side at 250 psig
    Superheat 100 subcool 9
  5. #4
    Southold, NY
  6. Likes dieseldude liked this post.
  7. #5
    Northern Calif
    IT'S Broke, replace it!!
    I'm not young enough, to know everything...
  8. #6
    either the compressor is not "on"
    or you have both hoses on the same high side
    or you have your knobs open
    Tell your Cat I said "Psst Psst Psst"
  9. #7
    As a Tech, please provide as much information as possible.
    Let's start with the model number of the unit in question, and any other information you can provide.
    If you want the best assistance, you will have to get into more detail.
    There is no such thing as too much information.
  10. #8
    Jan 2012
    Missouri, USA
    Broken compressor shaft? Let’s play 1 million questions.
    Residential or Commercial?
    Refrigeration or comfort cooling?
    Scroll or recip?
    Refrigerant type?
    Model and serial numbers?
    Volts amps rated and as tested?
    Etc………..
  11. #9
    Southold, NY
