Results 1 to 16 of 16
Thread: Commercial RTU Replacement - Can it be a different brand?
    May 2022
    For a commercial RTU, is it okay to change brands as long as the specifications are the same as the existing RTU? What else would need to be changed/modified? (i.e. controls, curbing, etc.).
    Virginia
    I moved this thread to the "AOP Commercial HVAC" forum where questions on Commercial equipment should be asked.
    Please take note of the location of this forum, as the "MOVED" icon in the other forum will only last a day.
    Jun 2014
    Dover, DE
    The curb can be different between brands, and require a new curb to be installed or a curb adapter to be used.
    “I haven’t failed. I’ve just found 10,000 ways that won’t work.” - Thomas Edison
    “It’s not whether you get knocked down, it’s whether you get up.” - Vince Lombardi
    Jan 2010
    Let's start with whatcha got and whatcha thinking.
  5. Likes dan sw fl, R600a liked this post.
  6. #5
    Carrier, from the 80s on, have had a standard footprint. All the others have a Carrier footprint model in their line to compete with Carrier. Otherwise you have to use a curb adapter, which sometimes can get pretty ugly. So like 99 said, details of what you have is the best start.
    If you don't have a common unit, a GOOD dealer would look for a unit with a very close match to the old one to avoid a hideous adapter which can hurt airflow. Against my wishes, my boss sold a Rheem Carrier footprint unit to replace a Trane. The curb adapter was UGLY. He could have replaced with another Trane or Lennox for a very short adapter.
  7. Likes Special-K liked this post.
  8. #6
    May 2022
    We have an Engineered Air RTU with a Prairie Controls thermostat. It is a large beast and very expensive. I'm wondering if everything would have to be changed if we went with a different brand. (i.e controls, thermostats, communication software, curbing, etc.). Let me know if you need more info.
  9. #7
    Jan 2010
    Is it a zoned system ?
  10. #8
    May 2022
    Yes, I believe so
  11. #9
    Jan 2010
    Do you know how many ton the unit is ?
  12. #10
    May 2022
    Not 100% sure but if I convert the supply CFM to tons it comes to 25
  13. #11
    Jan 2010
    Based on 400 ?
  14. #12
    May 2022
    I tried again. This time I used the btu method. 140/12 = 11.66 tons. Maybe I have no idea what I’m doing?
  15. #13
    Virginia
    Quote Originally Posted by Roboito View Post
    How about posting the model number of this unit.
  16. #14
    May 2022
    FWB - 252/DJ - 140 - 0
  17. #15
    Jan 2010
    Looks similar to this
  18. #16
    May 2022
    That might be the newer version? I think ours is from 1993 and quite a bit longer. I can’t figure out how to post pics on here. I would post a pic if there was an obvious button like “add attachments”. If there is, I can’t find it.
Quick Reply Quick Reply
Register Now
Log-in
Tags for this Thread
  • You may post new threads
  • You may post replies
