+ Reply to Thread
Results 1 to 11 of 11
Thread: Frigidaire heat pump issues
    Apr 2022
    I'm working on a frigidaire heat pump. I had a restriction and changed the txv and drier and flushed and added new gas. It ran for a couple of weeks and now I'm pumping down and have 1 degree sub cool and sky high super heat. When I go to heat liquid pegs to 600 and suction is good. I'm missing something I just don't know what. I have good air flow. Indoor coil is micro channel if that matters.
    Southold, NY
    Pull and weigh the charge.
    Jan 2010
    What is the outdoor metering device ?
    Apr 2022
    Txv
    Jan 2010
    Which txv did you replace ?
    Jan 2010
    Which type of filter drier did you use ?
    Apr 2022
    Only has txv in air handler and I replaced it with oem. Used a biflow filter, and the condenser has a piston
    Jan 2010
    Have you tried warming the TXV power element bulb ?
    Jan 2012
    Missouri, USA
    Is there a bypass around the txv with a check? Did you pull the orifice when it was open?
    Jan 2010
    Sea to Sky
    What is the temperature or even better, the pressure drop across the filter drier?
    Sent from my SM-G965W using Tapatalk
    tenn
    is it original a coil had several nordyne micro channels given to me warranty and shoulds have been copper and tubes
    birdman
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
