Results 21 to 34 of 34
Thread: noodle scratcher...randomly overcooling walk in cooler
  1. #21
    Mar 2022
    I would change your Anti Short Cycle to 5 minuets.
    Cut in at 40 with a 5° differential
    update - I chatted with Emerson and they said replace the controllers. not what i was expecting from the mfg. the support person suggested that it could be amp draw from the compressor and that the settings in the controller can affect the contacts ?!?!!?
    ill try changing the antishort from 1 to 5.
    any other theories and ways to find whats causing the random 60 minute overcool is so appreciated!
  2. #22
    Jan 2010
    The control is only wired to the solinoid correct ?
  3. #23
    Southold, NY
    Quote Originally Posted by PharmaPhridge View Post
    Tell the Support person hes full of $hit!
    the controller closes the EEV or solenoid valve and the compressor pumps down.
  4. #24
    Jan 2010
    Unless he's got the controller wired to the contactor 😲
  5. Likes R600a liked this post.
  6. #25
    Mar 2022
    i agree the support person was not helpful. the controllers are wired to the solenoids. the low pressure switches are wired to the contactors. (rem two independent units).
  7. #26
    Mar 2015
    Medford, N.Y.
    Doesn't the Keeprite evap MN# start w/ the letter K, like KLV ? Are the evaps facing/blowing into each other?
  8. #27
    Mar 2022
    good question..two keeprite units are installed in the ceiling and opposing each other about 12 ft apart. however they are never running at the same time and are completely independent of each other.
  9. #28
    Mar 2022
    thanks a million PECSMG! since i updated the antishort to 5 minutes no excursions! any thoughts on why this works beyond whats in the manual?
    Name:  antishort update april 7th.jpg
  10. #29
    Jun 2002
    Ft. Leonard Wood/Waynesville Missouri
    Short cycling keeping the compressor on I would think. PC you are the hero bro.
  11. #30
    Jun 2002
    The default is 5 too start.
  12. #31
    Poodle Head Mikey's Avatar
    Poodle Head Mikey is offline Membership Chair/ARP Committee / Professional Member*
    I try to stay as far away from myself as I can.
    Where exactly do the sensors "hang from" the evaporators?
    Are the sensor probes always directly in the inlet air stream to the evaporators?
    PHM
    . . . the units are . . . each controlled by their own Emerson controller 16e09101. The sensor probes hang from the evaps.
    Periodically, we are observing overcooling from a setpoint of 5C +/- 1C to about -6C. . . .
    PHM
    When faced with the choice between changing one's mind, and proving that there is no need to do so, most tend to get busy on the proof.
  13. #32
    Mar 2022
    They hang from the sides...Name:  temp probe 1.jpg
Size:  58.8 KBName:  temp probe 2.jpg
  14. #33
    Problem: System operates below setpoint at times.
    Possibilities: Either the compressor refrigeration does not respond to the temperature controller contacts opening - or the temperature controller contacts do not open at the lower set point.
    A way to determine which would be an independently powered latch-out-relay circuit across the temperature controller contacts with the NC relay contacts powering a light. If you see a too-cold spike in the temperature monitoring graph and the light is out - the contacts opened and the problem keeping the compressor operating to cool below set point is elsewhere.
    Is this WIC inside a building or is it an exterior unit?
    Can you correlate the too-cold-spike issue with the ambient and/or weather conditions in any pattern-establishing way?
    PHM
  15. #34
    Jun 2002
    Close enough to return. But I would have put a union in that drain for cleaning.
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
