Page 5 of 5 FirstFirst 12345
Results 81 to 86 of 86
Thread: Efficient Duct Design? I have concerns
  1. #81
    Poodle Head Mikey's Avatar
    Poodle Head Mikey is offline Membership Chair/ARP Committee / Professional Member*
    It is never too soon to begin making things better.
    Quote Originally Posted by Jimmy111 View Post
    Why would it make it the perfect time??
    PHM
    The conventional view serves to protect us from the painful job of Thinking
  2. Likes R600a, jbhenergy liked this post.
  3. #82
    Oct 2016
    Quote Originally Posted by Scoobie View Post
    I’d say you can’t make the coil to big, within reason. But you can move to much air through a coil. Humidity control is all about how cold you get the air leaving the coil. And that’s all about how much air per ton.
    Dan, what do you dislike about this post? Just curious.
  4. #83
    Mar 2016
    Dayton Oh
    Even at 800 cfm with a 2t outdoor and 5t indoor your not going to dehu any better I reckon.
    Unless your going to run your sst at 35*
    There is so much surface area to that coil that your sst will likely be just a few degrees shy of DAT.
    Again looking at the super high seer units, they have massive indoor coils and higher SST when charged to the proper subcooling.
    Look at the coils from the 70’S they were tiny but ran a low sst. Today we find them in the 50* range.
    Maybe I’ll get a hair up my behind and hook up to my unit. 16seer 3 t with 4 or 5t coil can’t remember at the moment
  5. Likes R600a, Scoobie liked this post.
  6. #84
    SW FL
    Just curious.
    Follow the HVAC DESIGN PROCESS _ FIGURE 3
    Adhere to
    Building Codes ___ Extended Performance Data SHALL BE USED,
    ACCA Guidance,
    AHRI Selections.
    Use vendor selection software
    _____ after an accurate Manual J calculation is verified.
    Designer Dan __ It's Not Rocket Science, But It is SCIENCE with Some Art. _ _ KEEP IT SIMPLE & SINCERE ___ __ www.mysimplifiedhvac.com ___ __ Define the Building Envelope & Perform a Detailed Load Calc: It's ALL About Windows & Make-up Air Requirements. Know Your Equipment Capabilities
  7. #85
    Oct 2016
    Adhere to
    ACCA Guidance,
    AHRI Selections.
    I was thinking more like an Aaon unit. A nominal 10 ton unit might have 1500cfm of air cooling it down to 48 deg or so. It still works okay. I was not suggesting mismatching stuff.
  8. #86
    Jun 2022
    Washington
    Interesting read.
    Been going over some of my old load calcs from 20 years ago. Boy, it really is a garbage in, garbage out method. In the last couple of decades I have learned that you need a balance between load calc, duct sizes, experience, and good old common sense.
