+ Reply to Thread
Results 1 to 8 of 8
Thread: TACO Self Sensing Pro Balance
    Nov 2021
    Anyone have any experience with TACO Self Sensing Pumps, namely the Pro Balance feature? Marketing fluff/brochures say it eliminates balancing for the secondary/variable flow system. From what I can tell, you have to define a duty point and establish a control curve (that represents system resistance) and the Pro Balance algorithm supposedly finds a "true" system resistance. It's vary unclear of how this works and what's really unclear is how this eliminates balancing all together.
    I was wondering if any T&B folks have worked with this pump system yet.
    Jan 2010
    If you're lucky @ Wayne will chime in being his specialty. 😉
    Feb 2016
    Louisburg Kansas
    I have worked with a lot of Taco pumps etc. but not familiar with this one. Having said that there are ways the pump can be feed enough info to control total flow but the system is not self balancing. To self balance every coil needs the controls to balance it.
    No man can be both ignorant and free.
    Thomas Jefferson
    New Mexico
    I wonder if it's similar to ECM motors overcoming static.
    We are here on Earth to fart around ......Kurt Vonnegut
    You can be anything you want......As long as you don't suck at it.
    USAF 98 Bomb Wing 1960-66 SMW Lu49
    May 2009
    2 cents....
    I didn't do any real research, but from what I've found, it's pretty simple. It appears to be a self contained pump and drive unit.
    Likely carries an onboard pressure sensor to control the drive to a setpoint.
    Kinda like a first cousin to a full blown primary variable.
    This still would not eliminate the need to balance the field.
    Unless the engineering and install were perfect.
    Chicago area
    Bell gosset has a similar product.
    We talked about it in a balance class. The instructor said he contacted Bell Gosset about how it works.
    What they told him was essentially its monitoring the horsepower via very closely monitored amperage.
    The amperage was either calculated, or otherwise added to the pumps design curve. More amps, more flow.
    As far as how to set it, I could not say. Never worked with either one.
    This was a few years back. But from my experience, anything like this, never works as intended. Either cause its never really set up right, or a design flaw, or a combination of the 2.
    Feb 2016
    Louisburg Kansas
    These systems can work well but are often not set up (calibrated) properly. I balanced a courthouse several years back that had never worked right since installed. I was called to balance it after the second or third attempt to redesign and make it work right. The first problem I had was the engineer tried to tell me how to do part of the balance. He got upset when I told him I was going to balance my way and pointed out a major design error he made. I explained why the controls didn't work properly and that the pump current draw should be the same on all the pumps that were running but wasn't. The top dog was a lady with some brains and had the contractor modify the screwup my way and the system worked perfectly.
    Thomas Jefferson
  8. Likes heatingman liked this post.
  9. #8
    Apr 2020
    va
    Armstrong sensorless work?
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
