+ Reply to Thread
Thread: Lennox xc 25 not dehumidifying
    Nov 2021
    Hi
    I have three ac units in my house all Lennox xc 25 two of the units are working fine humidity is about 44 +/- the third unit which is only in the bedrooms is running humidity in the 60-65 range and then finally getting down to 56-58. This unit has a damper system but all three zones are within 1-2 degrees of humidity. The following are the pressure readings
    Low side- 128
    High side - 290
    Super heat - 17
    Subcool- 5
    All units use the I comfort thermostat and are set to 40% humidity. Any help would be much appreciated. Thanks
    Sep 2009
    Marietta, GA
    try changing your filters and washing your outdoor units...
    wHen I diE I hOpe gOd haS mErcy oN my SiNful LifE
    Sounds like it may simply be over sized.
    Aug 2012
    central Minnesota
    Try slowing the blower speed so the air going across the indoor coil isn't moving too fast to condense
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
