+ Reply to Thread
Results 1 to 7 of 7
Thread: Hobart C44A need to increase wash temp.
    Aug 2015
    Elbert County, GA
    Hey Folks,
    Does anyone know where I can get a copy of the service manual for a Hobrt C44A dishwasher or know how to adjust the wash temp. It's a 140 and I need it to be 160f. The machine has a solid state control in a little cardboard enclosed box if that helps, 12135112
    Thanks in advance,
    Southold, NY
    Quote Originally Posted by rhkohl View Post
    Hey Folks,
    Thanks in advance,
    https://static-pt.com/modelManual/HO...=1532002605915
    Aug 2015
    Elbert County, GA
    Thanks but this isnt a service manual, it just says this about setting the wash tank temp,
    "The tank water temperature is regulated by the solid-state thermostat. The thermostat is preset at the
    factory and no adjustment should be required. If an adjustment is necessary or the machine is to
    operate low temperature, contact your local Hobart service office. Use thermometers for verification
    of proper water temperatures"
    I need to know how to set the control from 140 to 160 on this washer.
    Jan 2010
    So is it currently set for low temperature or has something changed that the high temperature settings is no longer accurate ?
    Southold, NY
    Page 26 troubleshooting. Water level float not closed'
    incoming water temp too low
    Jan 2016
    The triangle in the Keystone
    I’m not sure which temp control you have but they usually have a tiny potentiometer on them that adjusts the set point. 20 deg is kind of a lot though. I’d confirm the thermometer output while your there too. See how much the control gives you but it might need replaced.
    Aug 2015
    Elbert County, GA
    I think the control is in a litte cardboard box. An I assume it's set to 140. I'll have to dig into it a bit more.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
