Results 1 to 8 of 8
Thread: Commercial installer looking to switch over to TAB
    Oct 2021
    Im currently in year 2 of my 5 year apprenticeship in metro Detroit. Ive done a year in the shop and a year in the field. Im considering switching my career path to TAB I was just wondering whats the long term outlook for job security being a tab guy?
    May 2009
    The more expensive energy gets, the more interested people get in efficiency.
    Balancing systems saves money.
    The need for Test and Balance should only increase in the future.
    If T&B is where you think you want to go, start learning systems now. Mechanical systems, Water, Air, Constant Volume, Variable Volume, Piping, Electrical, Sheetmetal, Chillers, DX, Safety Systems, Control Systems, Blueprints, Computers, and more..... Plenty of math, formulas, as well as physics and thermal dynamics concepts to learn too. Many T&B companies offer Vibration Analysis services too.
    Learn how systems are designed, and how they are designed to operate.
    Along with learning about all those systems and components, you need to learn about sequences of operation.
    You will not learn all you need to know from a book, or a classroom. You need to work directly with a mentor or two, who "honestly" know what they're doing.
    With steady work, the average tech will start to get a handle after a few months, and after a year or so, will normally be good enough to handle most simple balance jobs.
    There's a lot to learn, but if you learn it one bite at a time, it's not that difficult. But you must be dedicated. Not everybody can do it, or be good at it.
    There are some half assed t&b guys out there. Some think they are smarter than they are, or want you to think they are, and others who just don't care........don't be that guy.
    Keep in mind, as you learn, there are many more systems, pieces of equipment, and sequences of operation, other than what you will see in the northern climate of Detroit.
    I'm from the south, and we don't normally have a high concern for glycol levels in our water systems, and we tend to use a lot of electric heat strips for reheat. (little things like this)
    There are still lots of old pneumatic systems out there, and if you want to work when nobody else can handle the job, you might also consider learning pneumatics.
    Maybe Wayne can chime in here too.......
    Oct 2021
    Artrose, thank you for your answer. I’m in a place where if I started t&b today I’d have 2.5-3 years to learn the trade. Your answer helps a lot.
    Southold, NY
    Quote Originally Posted by Bigmilo265 View Post
    I’m currently in year 2 of my 5 year apprenticeship in metro Detroit. I’ve done a year in the shop and a year in the field. I’m considering switching my career path to TAB I was just wondering what’s the long term outlook for job security being a tab guy?
    Is this in the same union? Are you willing to give up the time and effort already put in? Are you willing to give up accumulated Pension, Annuity, Seniority?
    Stick it out for another 3 years, see how it goes, then if you want the change do it. At least that way you can always go back.
    Oct 2021
    Pecmsg
    Same union and the only issue with passing up on the opportunity is that when you are a journeymen the contractors wont want to train you due to the high rates theyll have to pay you. If I dont cut it as a t&b tech then I can always go back to the field.
  6. Likes crazzycajun liked this post.
  7. #6
    Southold, NY
    Pecmsg
    Same union and the only issue with passing up on the opportunity is that when you are a journeymen the contractors won’t want to train you due to the high rates they’ll have to pay you. If I don’t cut it as a t&b tech then I can always go back to the field.
    Then its up to you.
    Bottom line never ever pass up opportunities to learn. You'll never know when you'll need that knowledge.
  8. #7
    Dec 2018
    Phoenix, AZ
    SMW Union? How many years are Common Core with the other Service Trades in your Union?
  9. #8
    Jan 2020
    Job security in the TAB field is much better than it is for an installer. Even when construction slows down, we still have annual testing in hospitals, re-certifying fume hoods in Lab. facilities and testing in any other facilities that have EH&S requirements relative to airflow and space pressures. If you have good math, organizational skills and can communicate well with others, it may be something to consider. If you are in Local 80, talk to Matt O'Rourke about taking some TAB classes at the hall.
