Results 1 to 12 of 12
Thread: Mini Splits and required voltage
    Oct 2021
    I have an apartment complex that runs an ageing Geothermal heating and cooling system, I want to shut this system down and install mini split units in each apartment. The current systems heat pumps all run on 277 volts, there is 480 volts at the panel. The current transformer I have is at capacity and I can't install mini splits that run on 240. (duh) Is there a mini split unit I can get here in the states that runs on 480 volts?
    Feb 2018
    Bay Area, Ca
    Not that I'm aware of. You can do a complex system that could work(big $$$$$$) but the FCU's still run on 240V.
    Sent from my SM-N960U using Tapatalk
    Jan 2010
    How many amps is your 480 volts ?
    Oct 2011
    Culver, Oregon (Central OR)
    Just split one leg into 2 legs and wire nut off the other...duh!!!!
    "Life, Liberty, and Levin!"
    Feb 2018
    Bay Area, Ca
    Yeah. And the merry little leprechaun will come and install it for you.
    Jan 2010
    Cincinnati, Oh
    Your cheapest option is probably going to be replace the geo.
    Otherwise your looking at a VRF system.
    Jun 2019
    you need a transformer. Maybe some units have a separate power supply inside not tied to the motherboard but I would not bet on it. Will cost you more and you have no warranty.
    Southold, NY
    Quote Originally Posted by gustavhorna View Post
    Why No Warranty?
    Apr 2003
    Maple Grove, MN
    Quote Originally Posted by ElderSkippy View Post
    I don't have anything to add, but are you saying each apartment has a 480V breaker box in their apartment? If so, does each apartment also have a transformer feeding 230/120V to another breaker panel? I don't work in many apartments, but this seems a little unusual to me. Please clarify, just for my own curiosity. Thanks.
    If at First You Don't Succeed, Skydiving Is Not for You.
    Southold, NY
    Seeing how Heat is required Im ASSUMING separate supplies for the HVAC then dropped down to lighting and others.
    Now it could be metered with the A/C or just the lower voltage if metered at all?
    New Mexico
    Unless it's bad broke it's almost always cheaper to fix than replace.
    An apartment would probably require 2 or maybe 3 air sections depending on layout, wall mount or cassettes. Can't talk $$ here. Then there's the electric service, piping add up.
    In it's day did the geothermal perform OK? How broke is it?
    Give me a relay with big enough contacts, and I'll run the world!
    You can be anything you want......As long as you don't suck at it.
    If a person wants to create a machine that will be more likely to fail...Make it complicated.
    USAF 98 Bomb Wing 1960-66 SMW Lu49
Tags for this Thread
