+ Reply to Thread
Results 1 to 15 of 15
Thread: Oil tank repair
    East Haven,CT
    Oil tank repair
    Jun 2012
    Northern NV
    Guy was a body man at a repair shop?
    AND in a basement I presume... Flame on!
    “A dying culture invariably exhibits personal rudeness. Bad manners. Lack of consideration for others in minor matters. A loss of politeness, of gentle manners, is more significant than is a riot.”
    ― Robert A. Heinlein
    Jan 2012
    Broomall, PA
    50 year old tank. Now when it fails, he probably will be fully responsible for the cost of clean up.
    If I do a job in 30 minutes it's because I spent 30 years learning how to do that in 30 minutes. You owe me for the years, not the minutes.
    Helpful Calcs, tips, tricks on my YouTube channel: https://www.youtube.com/channel/UCgm...TUTAdKmqRiTDEg
  4. Likes Zamoramax liked this post.
  5. #4
    Jan 2010
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    Southerner here. Is something wrong with that?
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
  7. #6
    Oct 2020
    N. Central Illinois
    I've never understood why oil tanks don't have a sump drain. They are installed with a tilt to the rear so that all the water and sediment settles away from the outlet. Eventually, however, it will build up enough to start collecting in and clogging the filter. This probably doesn't take too long for a tank situated outside or where there is a lot of temperature change causing condensation inside the tank. Just like in diesel fuel, the water causes "slime" growth which further clogs the filter, not to mention rotting out the bottom of the tank. It's pretty ugly when the weakened tank busts and fills up your basement with a few hundred gallons of stinky oil.
  8. Likes Juan Madera liked this post.
  9. #7
    They did a good job , its not dripping ....
  10. #8
    Jan 2010
    Now let's wait and see what happens when they fill it 🤔
  11. #9
    Jan 2012
    Broomall, PA
    Quote Originally Posted by Viewsaver View Post
    I've never understood why oil tanks don't have a sump drain. They are installed with a tilt to the rear so that all the water and sediment settles away from the outlet....
    Then they weren't installed properly. By code they are to be installed 1/4" per foot fall toward the drain. The one pictured with the side outlet, and the end seamed hasn't been made since the late 70's simply because the seam fails and the outlet on the side is the weakest part of the entire tank.
  12. Likes Viewsaver liked this post.
  13. #10
    New Mexico
    When I first got involved in hvac I saw a gut cut up an oil tank with a cutting torch. I expected a fire but it didn't lite up.
    Thinking about the first guy that tried that. "I wonder what would happen if I took my torch and..........".
    We are here on Earth to fart around ......Kurt Vonnegut
    You can be anything you want......As long as you don't suck at it.
    USAF 98 Bomb Wing 1960-66 SMW Lu49
  14. Likes R600a liked this post.
  15. #11
    R600a's Avatar
    Jul 2019
    Quote Originally Posted by hvacker View Post
    It was probably somebody like me who tried it first and thought hey that'll make a cool boom and was sorely disappointed.
  16. #12
    Jan 2012
    Broomall, PA
    They cut them long ways, burn them out, make grills out of them. Probably don't want the first dozen bbq'd items off them.
  17. Likes R600a liked this post.
  18. #13
    New Mexico
    Quote Originally Posted by STEVEusaPA View Post
    They can hold the whole hog.
  19. #14
    in a house, Appomattox, Va.
    some farmers cut them open for cattle feeders.
    some one near here was scrappin a large gasoline tank, wasn't dry enough, people heard the explosion nearly two miles away.
    Col 3:23
  20. Likes STEVEusaPA liked this post.
  21. #15
    Jan 2012
    Broomall, PA
    Quote Originally Posted by billygoat22 View Post
    Yeah for a few dollars for some dry ice…
  22. Likes R600a, sammyray liked this post.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
