Results 1 to 15 of 15
Thread: Tower drain lines
    Jul 2021
    Las vegas wish I owned hell... I'd live there and rent vegas out since it'd be cooler...
    Cool Tower drain lines
    Did this today and I feel like I did a fine job.Name:  20210924_134858.jpg
    For reference since I suppose the picture is misleading that's 2in
    Copper.
    Previously with bad ball valve just spewing out precious chess.
    Last edited by DesertNomad; 09-24-2021 at 10:50 PM. Reason: Adding pictures from before.
  2. Likes IceWhiteice liked this post.
  3. #2
    Jul 2019
    Oklahoma home its in the name.
    I don't know anything about it but it sure looks pretty.
    Sent from the Okie state usin Tapatalk
    "Is this before or after you fired the parts cannon at it?" - senior tech
    All opinions subject to change without notice.
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
  4. #3
    Apr 2010
    Just curious, why didn't you just unsweat the valve? Why remake the whole thing?
  5. #4
    Southold, NY
    Quote Originally Posted by CHAINIK View Post
    Ill assume the cutting permits involved! 2 or 3 men for up to an hour, Sawzall and Pro Press!
  6. #5
    New Jersey
    Pro press sure makes life easier on bigger pipes, don't have to worry about water still draining also.
    Sent from my VS501 using Tapatalk
  7. #6
    Apr 2010
    Quote Originally Posted by chander View Post
  8. #7
    Jul 2021
    So I did this by myself... and the reason I didn't unsweat it is because of the continuous water flowing out. Which makes brazing or soft soldering a lost cause. Plus look at it it's a shiny and pretty.
  9. Likes R600a, chander, BALloyd, heatingman, Wheelbaron liked this post.
  10. #8
    Southold, NY
    Quote Originally Posted by DesertNomad View Post
    I hope you NeverSeized those unions!
  11. #9
    Jul 2021
    Well a little bit of pipe dope and blue monster
  12. #10
    Southold, NY
    Better then nothing!
  13. #11
    New Jersey
    NeverSeize, the gift that keeps on getting everywhere except for where you want it !
    Works well nevertheless.
  14. #12
    Jul 2021
    Well alternatively I had nylog and the dreaded bottle of leakstop
  15. #13
    Southold, NY
    I even put it on Roto Lock valves and the new damn Copeland Steel access valves. Who in the hell allows Steel on a suction service valve?
  16. Likes R600a liked this post.
  17. #14
    Chicago area
    Everyone. Especially the larger ones.
    Steel is standard.
  18. Likes GoCougs liked this post.
  19. #15
    and next year you or someone will be replacing that pos tower, if that is what ya what to call it. good work though!
