+ Reply to Thread
Results 1 to 8 of 8
Thread: Evaporator coil condensation water issue
    Chapel Hill
    Hey pros,
    I have this A coil inside the air handler. The condensate water dripping at the middle of the A coil instead of drip into the drain pan.
    The bottom of the return air box is filled with water.
    I cleaned the drain line , I cleaned the evaporator coil. The water still dripping down from at the center coil.
    Freon level is good, cooling the house very well. All zone damper are open and closed properly.
    What else am I missing? I'm afraid I will have mole issue in the unit.
    Any suggestion will be helpful. Thanks
    jcrew4242
    Mar 2015
    Medford, N.Y.
    How old is this system? Got a P trap? Air filter?
    in a house, Appomattox, Va.
    I've seen them drip if the coil wasnt cold all way to top. and seen them drip due to something coating the coil, 409 was the only thing that worked on one.
    Col 3:23
    Chapel Hill
    Quote Originally Posted by TechmanTerry View Post
    It is 9 years old.
    P trap on both Primary and secondary drain. Directly into the pump.
    jcrew4242
    Sep 2018
    Metro Detroit
    Something is causing the water not to cling to the coil and drain properly.
    - if somehow the bottom of the coil was much warmer than the top of the coil. Making the bottom “dry” while the top is “wet”.
    - oil or some other hydrophobic substance on the coil.
    -the evaporator saturation temp is too low causing ice formation.
    May 2014
    Bay Area California
    First time I saw that problem had to go back 3-4 times. Finally pulled the coil, took it outside, and used a high pressure cleaner to clean it. Took care of the problem. That was maybe 30 years ago. Seen it two or three times since.
    I do a triple evac with nitro to remove non condensables.
  7. Likes R600a liked this post.
  8. #7
    Nov 2020
    Illinois
    What brand ? Carrier had an issue with there A coils in air handlers doing this. Fix was a “wet ability” solution you sprayed on the coil
  9. Likes Patech liked this post.
  10. #8
    Chapel Hill
    Quote Originally Posted by Averagetech37 View Post
    It is a Trane air handler.
    I am going back there tomorrow.
    Doing some deep coil cleaning. Hope for the best.
    jcrew4242
  11. Likes BBeerme liked this post.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
