+ Reply to Thread
Results 1 to 14 of 14
Thread: Flow balancing manifold on a budget
    Jun 2008
    What do you guys use for a manifold when doing flow balance. I saw a few online, they were crazy expensive. Is it possible to use a digital gauge, and a tee with 2 refrigeration hoses with ball valves? Just flip flop the ball valves to get your reading?
    i use an old manifold with 3 hoses. on the suction gage side, i have a low range digital gage from Dwyer and on the discharge side i have a high range digital gage from Dwyer. this allows me to have as accurate a reading as i want...maybe not as accurate as a true flow gage, but good enough for the girls i date.
    "Right" is not the same as "Wise".
    Just because you can measure it, doesn't mean it is important. Just because you can't measure it, doesn't mean it isn't important.
    Nov 2011
    CO
    I bought a digital gauge and aluminum manifold online. Still have to put it together...I think I'm about $300 in.
    Jun 2021
    Can you please share sources you bought it from?
    Nov 2011
    CO
    Nov 2011
    CO
    Most important thing when selecting a gauge is the range. The larger the range, the less accurate it will be.
    If you need high accuracy, do what Jay suggested, and use 2 gauges...one with a low pressure range, and one for a higher pressure range.
    Jun 2021
    Quote Originally Posted by 71CHOPS View Post
    I am trying to do the same for TA (balancing) valve with the needle connection (blue and red on photo).Name:  IMG_8924.jpg
    So far no luck finding it, do you know where?
    Nov 2011
    CO
    Look at the link I posted to the other thread about the same topic.
    Jun 2021
    First, thank you.
    I am sorry but can not find the answer for the needles themselves.
    Where do you find those?
    The gauge is not a problem to find.
    Nov 2011
    CO
    Oh....
    Here's the smaller bell and gosset type.
    https://www.supplyhouse.com/Bell-Gos...Probe-Set-of-2
  11. Likes dieseldude liked this post.
  12. #11
    Nov 2011
    CO
    Here's the part number for the larger armstrong type probes.....check that though, it may be the entire kit, not just the needle probes.
    https://www.winstelcontrols.com/item.../ARM570147-010
  13. #12
    Apr 2020
    va
    Budget: Use tee, nipples, ball valves, plastic tubing, and a selection of 2-3 pressure gauges. My cost $0, industrial customer donations.
    Orange research dp gauge or Dwyer dp commercial options.
    Pete's plugs & needle probes.
  14. #13
    Jun 2021
    Thank you guys
  15. #14
    Jun 2008
    Quote Originally Posted by ishaitz View Post
    Thank you guys
    Agreed, thank you!
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
