+ Reply to Thread
Results 1 to 2 of 2
Thread: Heatilator 3138 - want to seal up fans / vents to make it a "normal" fireplace
    Sep 2021
    los angeles, CA
    Confused Heatilator 3138 - want to seal up fans / vents to make it a "normal" fireplace
    So, I'm renovating my own home in Los Angeles and for some reason I cannot fathom, the previous homeowner installed both central heating and AC, *and* a Heatilator 3138 (natural gas) when he made an addition in 1980.
    The Heatilator 3138 pulls fresh air in from inside through two fans, circulates that air in a chamber that surrounds the firebox to warm that air, and then pushes that warm air into two different rooms though outlet ducts to warm those other rooms.
    Things I don't need in Reseda? Supplementary heating in a house that already has central natural gas heat.
    Well, the fans were loud and not really functional when I got the place, so I removed power to their switch- and then proceeded to never use my fireplace again for 15 years.
    Cut to this week when I'm removing drywall in preparation for a remodel and I realize this is the perfect opportunity to just- remove the two broken fans and seal up the inlet and outlet circulating ducts (2 each) so I can have the oncoming drywall contractors seal up the outlet vents.
    Essentially, I want to go from a heat circulating fireplace (with nonfunctional fans and useless vents) that I never use to a "normal" fireplace with no circulating fans or exhaust fan vents that I never use, but with an updated door set that isn't 1979 gold and no extra grills. And that I can make look like not a craptastic fireplace from 1980.
    It seems like a harmless enough idea, seeing as though I am not touching anything in the fire box, not touching the front fresh air inlets, or mucking about with any combustion venting, it should be a reasonably safe thing to do.
    However, I know enough to know that I don't know enough about the subtleties and safety around fireplaces and chimney venting.
    I may be foolish, but I'm not stupid. I mean, not usually.
    Before I call a fireplace specialist and waste his time or my money, I thought I'd see if anyone has done this before- or if anyone here has enough experience with this fireplace unit to tell me in no uncertain terms "You cheap bastard, if you do that it will be a disaster. Just get a new fireplace".
    Or, ideally, tell me "That shouldn't be a problem at all. You seem to have assessed the situation correctly. Just make sure you get a professional do do this work. Don't be dumb."
    Anyone?
    S.E. Pa
    Thumbs down Refer to the manual
    Blocking the air ducts will overheat the fireplace and probably burn the house down. It's out of warranty so why not replace it with a modern fireplace. That is, if you're even allowed to burn open hearth fires in Californiastan.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
