Thread: Imperial Kwik charge
    Aug 2021
    I have to charge a reach in cooler with 404a. I was planning on using a kwik charge adapter just to be sure no liquid enters the compressor. I see on the box for the Kwik charge that it will work on all units 1/2 ton or larger, does this mean that the device won't work as intended when using it on small appliances?
    Southold, NY
    47 years charging liquid. Haven’t killed one YET!
    Besides what are we talking 8, 10, 14 oz’s?
  3. Likes R600a liked this post.
  4. #3
    Jan 2010
    Your manifold is capable of doing the same thing.
  5. #4
    Southold, NY
    Now that you’ve passed the 608 exam time to forget all the BS they taught you and get edumacited!
  6. Likes R600a liked this post.
  7. #5
    May 2014
    Bay Area California
    Stick around this site, you'll learn a lot.
    Quote Originally Posted by AMF Mechanic View Post
    I do a triple evac with nitro to remove non condensables.
  8. Likes R600a liked this post.
  9. #6
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    I use the yellow jacket charging orifice because I find it convenient and they're cheap. Its certainly not required but I like to keep one on my 410a tank.
    If you're charging from a vacuum you can just add it to the high side and you don't need any kind of restriction. Most times I'm able to get the full charge into the high side as long as my tanks good and warm.
    Sent from the Okie state usin Tapatalk
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
