+ Reply to Thread
Results 1 to 20 of 48
Thread: M12 Hackzall
    Aug 2021
    M12 Hackzall
    Has anyone used the Milwaukee 12 volt reciprocating saw for roughing in boots and returns? If so how does it do? (I would be using the larger batteries).
    We're given a corded Sawzall but I'm a big fan of the 12 volt series and the little guy would be great if it can handle the job.
    Thanks for any input
    Mar 2018
    Virginia
    I have it and it’s nice because it’s lightweight and one handed but the m18 sawzall is a lot more aggressive and cuts a lot faster. I think there’s also an M18 one handed version.
    "I think Quantum tunneling would work great... "
    "Call a technician for God's sake. Or we'll see you on the news or the Dark Side of the Moon."
  3. Likes R600a liked this post.
  4. #3
    May 2018
    I had the M12 one hand version for a while, and it was just ok, not anything special, except light. I now use the M18 one hand brushless version and it is much more useful. It is a monster at cutting and much, much less vibration than the M12 version. If you can do it, I'd definitely go M18 all the way.
  5. #4
    Aug 2021
    Thanks for the replies, that's what I was expecting to hear....just not what I was hoping to hear ha. I never thought about vibration since it's so light, that would get old fast
  6. #5
    Feb 2018
    Bay Area, Ca
    If its just sheetrock do it. Anything more and naww. Get a fuel 18V.
    Sent from my SM-N960U using Tapatalk
  7. Likes JayMan7, dieseldude liked this post.
  8. #6
    Sep 2018
    Metro Detroit
    I used to use my m18 hackzall for cutting in vents on thick gauge commercial spiral duct. It worked great compared to my coworkers sawzalls. The cutting motion is cleaner. I feel like sawzalls are made for demo and hackzalls are made for cutting materials.
  9. Likes ga-hvac-tech liked this post.
  10. #7
    Quote Originally Posted by Patech View Post
    I tend to agree with this...
    IMO the M12 is for light work... the M18 is for heavier work...
    And a SawZall is for demolition.
    I use the M12 for lots of things... it seems to do the job nicely...
    If you are cutting a few holes in residential roof decking... or a few holes in metal duct... it works...
    If you are doing serious installation work... there is a M18 version of the M12 HackZall... just a little larger all over.
    Oh, and do not even consider the cheaper one... get the 'FUEL' one!
    GA-HVAC-Tech
    GA's basic rules of home heating and AC upgrades:
    *Installation is more important than the brand of equipment
    *The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
    *The value of comfort, over the long term; leave economic choices behind!
    Choose your contractor wisely!
  11. Likes Patech, Zamoramax, heatingman liked this post.
  12. #8
    May 2018
    I've used both 12v and 18v to cut holes in subfloor for vents and registers and I can tell you the 18v is much easier on the ole body to use. One of those Diablo blades and a one handed M18 will really go thru old plank sub floors in old commercial buildings like a hot knife thru butter.
  13. Likes ga-hvac-tech, Zamoramax liked this post.
  14. #9
    State College, PA
    If you get the fuel version of the m12 it is not too bad, much better than the version that is just brushless. If I need to just cut a few 2 x 4 's the non-fuel version works pretty good. I mostly use it for cutting in ceiling diffusers. It is a little smaller to use in the tight attics.
    Whichever way you go, spend the extra and get the fuel version. Big difference.
    I have not noticed the vibration issue others have mentioned. But I have not tried to cut in floor grills.
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
  15. Likes Zamoramax, R600a liked this post.
  16. #10
    Aug 2021
    appreciate the replies fellas, going to go the safe route with the m18 fuel (brushless) version
  17. Likes Zamoramax, ga-hvac-tech liked this post.
  18. #11
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    Quote Originally Posted by pmagorian View Post
    I have the M12 brushed and it's all the power I ever need. I honestly don't know that I'm going to be buying any M18 tools other than yard equipment.
    Sent from the Okie state usin Tapatalk
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
  19. Likes Zamoramax liked this post.
  20. #12
    Aug 2021
    we do new construction as well, does it hold up to cutting through studs and subfloor and whatnot for all the heat runs and returns?
  21. #13
    R600a's Avatar
    Jul 2019
    I don't think I'd want to do anything like that with it but it isn't even the brushless fuel version so upgrading to fuel would be a major improvement from my experience with the other brushless versus non-brushless tools.
  22. Likes Zamoramax liked this post.
  23. #14
    Jan 2020
    Winnipeg Canada
    I have both. If it's just for cutting boots, the m12 is fine. It's NOT fast, but really 2 minutes vs 45 seconds isn't a big deal.
    The m12 lives on my truck because it fits anywhere I need it to. The m18 is GREAT make no mistake. But it's pretty big and doesn't fit most places I need it to.
    Now if I'm just an installer, well I'll go m18 every time.
    But for what I'm doing, ( plumbing drains, the odd duct mod requiring a bigger boot, or cutting a bigger return through floor plates) the m12 is awesome.
  24. Likes R600a liked this post.
  25. #15
    Aug 2021
    Quote Originally Posted by R600a View Post
    That's the main reason I'd want it: for cutting out framing and subfloor in between stud spaces the small footprint would be super nice but I may be hoping for too much.
  26. Likes R600a liked this post.
  27. #16
    State College, PA
    Not sure what kind of wood Restaurant Mech is cutting with the M12, but around here there is what I call "Real Wood". Meaning 2X4's that actually measure 2" X 4" and subflooring that is actually 1" thick and cured wood. Don't think the M12 would do much with that.
    Many houses here from 20's, 30's & 40's. Many with plaster walls. Need a little extra power on these older homes.
  28. #17
    Feb 2018
    Bay Area, Ca
    Quote Originally Posted by joemach View Post
    Yeah. I've chopped a section off a 2x4. That cut must have taken 30 seconds. That was with a new milwaukee 9" fang tip blade. Figured 1 cut was worth the time over getting a circ or the 18v version.
  29. #18
    Jan 2020
    Winnipeg Canada
    I work on plenty of old fir built houses. M12 works just fine.
    Yes if you want ultimate speed then m18 is the way to go.
    But the reality is, m18 is twice as fast. Is 2 minutes vs 1 minute gonna cost you the job?
    If it is, then go big or go home. If it's once in a blue moon? That's why the 12volt stays on the truck.
    A cat d4 will move the same mountain a d11 will. It just takes longer
  30. Likes R600a liked this post.
  31. #19
    State College, PA
    Quote Originally Posted by Restaurant mech View Post
    Are you using the M12 fuel version?
    I only have the older version which I think is brushless, but not fuel.
    It is smaller and fits bertter in some of the tight attics when cutting in ceiling diffusers.
  32. #20
    R600a's Avatar
    Jul 2019
    I believe fuel is always brushless and non-fuel is always brushed.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
