Thread: I gave up!!!!
    Jun 2014
    I gave up!!!!
    A couple of weeks ago I posted about my compressor intermittently making a funny whistling noise and not starting up sometimes after putting some stop-leak in my system in hopes of sealing a leak in my evaporator coil.
    We bought our home 5 years ago and we've had nothing but trouble with our old Rheem system. From repair costs to it not really having much air movement, we've been unhappy with it.
    So, I gave up!!!!
    I had a York 5 ton system put in with a Honeywell thermostat and we love it.
    I purchased a York YFK60B21S Two Stage Compressor and a AVC60DX21 Air Handler. I had them put in a Honeywell thermostat and I'm loving it.
    So, how'd I do?
    Thomas
  2. Likes ksefan, dieseldude liked this post.
  3. #2
    Jan 2012
    Missouri, USA
    Great, i hope you get many trouble free years out of it. Cheers.
  4. Likes R600a liked this post.
  5. #3
    Jan 2014
    New England
    So, how'd I do?
    That’s Grrrreat! my hats off to you for doing your part keeping the global economy moving forward with this purchase.
    Shows that combo is a AHRI match gives 16 SEER and 12.75 EER. Needs the TXV as that coil comes with no metering device, and can accept either a TXV or a piston metering device. The X in the model number says no metering device came from the factory. The AHRI number shows AVC60DX21+TXV
    Dated 2016 thou page 6 section V discusses metering device, also discusses external static pressures checking, ( page 21 ) would be a good thing to check..
    https://www.google.com/url?sa=t&rct=...vgT-FGaDD4T3xV
    Active AHRI number 202142070
    If your state or local utility company has rebates that system should qualify. There is also the Federal Tax Credit.
    https://www.energystar.gov/about/fed...ty_tax_credits
    Make sure to register your system as manufacturers warranty decreases if never registered. California or Quebec need not be registered to receive the manufacturers maximum warranty.
  6. Likes Jim1959 liked this post.
  7. #4
    Jun 2014
    Thanks for the tip on the tax credit. I hadn't thought of that.
    Thomas
  8. #5
    SW FL
    Quote Originally Posted by thomas54 View Post
    _____________ a AVC60DX21 Air Handler.
    So, how'd I do?
    Thomas
    1. What is the Total Air Flow Rate ? > 1,840 CFM High Stage
    ___ _______________________ 1,196 CFM - Low Stage
    2a. What is the T.E.S.P. ? < 0.63" __ Total External Static Pressure
    _______ Figure 22 .. Manual
    __ ___ Completed Form, Page 25 Manual
    2b. _ What is the measured Blower Motor Power ? < 460 Watts High Stage
    3. What is the measured Supply Air Temperature AT the Air Handler Outlet.
    .. < 55.5'F with 76.0'F Room Temperature
    4. What is the Room Relative Humidity ? Consistently < 54%
    5. What is the refrigerant Superheat value in the afternoon? ~ 10'F
    ____ Refer to Yorks required operating value.
    How are u doing?
    FINE, IF all Five parameters exceed/meet the stated values.
    https://www.master.ca/documents/regr...uim-b-0216.pdf
    Designer Dan __ It's Not Rocket Science, But It is SCIENCE with Some Art. _ _ KEEP IT SIMPLE & SINCERE ___ __ www.mysimplifiedhvac.com ___ __ Define the Building Envelope & Perform a Detailed Load Calc: It's ALL About Windows & Make-up Air Requirements. Know Your Equipment Capabilities
  9. Likes ksefan liked this post.
