+ Reply to Thread
Results 1 to 20 of 30
Thread: My funky pool plumbing second edition.
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    A new to us and much larger filter going in.
    The nozzle was such high velocity that it was dangerous so I am installing two nozzles to reduce the velocity a bit. I got them in but it was after dark so I will have to get pictures tomorrow.
    It turns out inch and a half male adapters are extremely hard to find right now.
    Sent from the Okie state usin Tapatalk
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
    Northern Calif
    I have worked on many pools, pumps, filters and heaters. Let me know if you need assistance.
    I'm not young enough, to know everything...
    R600a's Avatar
    Jul 2019
    Quote Originally Posted by dieseldude View Post
    I could use an extra set of hands and some brain cells.
    This was me returning two bags of PVC fittings because I bought all 2 inch and needed all 1.5 inch.
    I returned them for store credit and went back and bought all inch and a half fittings and completely forgot T's and male adapters. I ended up making a third trip to home cheepo.
  4. Likes dieseldude, Turtleman liked this post.
  5. #4
    Northern Calif
    Always available, just draw something and send it, my dad, uncle and grandpa were all pipe fitters. I learned by osmosis.
  6. Likes R600a liked this post.
  7. #5
    R600a's Avatar
    Jul 2019
    Thanks. I appreciate it.
  8. #6
    R600a's Avatar
    Jul 2019
    Last time I put a lot of unions but I didn't put them where they would assist with alignment of the pipes. This time I am trying to think that through better.
  9. #7
    Jan 2010
    A very good friend on the left is a pool builder. Typically they do freeform fiberglass walls but this one is traditional.
    I think this pool is in the 70k range. I've helped him on many different jobs and lots of heater service calls. It's a fascinating trade but way to labor intense for me. Another friend I work with often dug the hole and took this picture from the excavator.
  10. Likes R600a, ksefan liked this post.
  11. #8
    Jan 2010
    This is the freeform style
  12. #9
    R600a's Avatar
    Jul 2019
    That is really cool.
    Our pool was built by a local guy at least 30 years ago and was made in sections which were bolted together. Eventually they got fiberglassed together due to leaks so it is one piece now.
  13. Likes VTP99 liked this post.
  14. #10
    R600a's Avatar
    Jul 2019
    Here is my progress. It is plumbed from the strainer up through the pump to the filter. Now I just have to get it back from the filter to the bypass fountain and then into the chlorinator and to the two jets.
    I went with an inline chlorinator because I got tired of floaters breaking and just throwing blocks of chlorine in the pool didn't seem to help much.
  15. #11
    R600a's Avatar
    Jul 2019
    The old filter was 1.4 ft² of effective filtration area and the new one is 2.2 ft² of effective filtration area. I am hoping that will help bring the pump discharge pressure a little lower because with the old filter it was 25 PSI. That pump is a monster.
  16. #12
    R600a's Avatar
    Jul 2019
    I was just getting this finished up so I could finish filling the pool up and fire up the pump today and I am one foot short so I'm having to run to home Depot to get more pipe.
  17. #13
    R600a's Avatar
    Jul 2019
    Ugly as sin but functional.
  18. Likes VTP99, dieseldude liked this post.
  19. #14
    R600a's Avatar
    Jul 2019
    I rigged it up with a inline chlorinator and today I finally got everything to stop leaking. The clorinator included an o-ring on the control knob that was too small so I had to use a automotive AC o-ring that was a little fatter to get it to seal. The pipe going vertical just before the black chlorinator is a fountain that sprays out over the water for the kids. Initially I thought I might use it for cooling the water when it was starting to get too hot I would run it at night to evaporatively cool the water but I find that I don't need it. The pipe that runs over the side of the pool beside the skimmer basket is just a second suction because the pump is so large. The new filter gives a filter head pressure of 18 to 20 psi clean.
  20. Likes ksefan liked this post.
  21. #15
    R600a's Avatar
    Jul 2019
    I am trying to decide between a Wi-Fi timer or a simple mechanical timer.
    I was looking at the one below.
    https://www.amazon.com/DEWENWILS-Out...NsaWNrPXRydWU=
  22. #16
    R600a's Avatar
    Jul 2019
    Ironically the mechanical one locally is double the cost of the Wi-Fi one online. I was going to buy the mechanical one locally if it was cheaper because I like spending locally but the price and the fact that I would prefer Wi-Fi control. It is hard to justify the mechanical one.
    I need to check what my local pool store has because I really don't like spending my money online.
  23. #17
    Hey 600...
    I bought a house with a concrete inground pool a few years ago...
    Had to learn about pools from scratch.
    Here are a couple of things:
    This site:
    Troublefreepools.com
    They are the guru site...
    LOTS of tech articles and a forum...
    This is where I learned.
    Next: Get a salt chlorine generator... it is like night and day... no more burning skin and burning eyes, the chlorine smell almost goes away.
    Next: Get a high end pool chemical testing kit, and do the full tests... it is fun to play with... and when you do the testing as recommended... and keep a log... after a year or so, you learn a HUGE amount about pool water chemistry!
    Next... Leslie's pool supply stores have a 'pool school' class... it is one day, costs a couple $hundred. You get a pool service certification... You could add that to the services you offer... I did the class, easy if you pay attention in class.
    I have about a dozen customers (hand picked, I do not advertise this service)... where I go 'open up' their pools, before AC season starts...
    Easy $$$...
    Now that I have posted, will keep an eye on your thread... see if I can help with stuff...
    GA-HVAC-Tech
    GA's basic rules of home heating and AC upgrades:
    *Installation is more important than the brand of equipment
    *The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
    *The value of comfort, over the long term; leave economic choices behind!
    Choose your contractor wisely!
  24. Likes R600a liked this post.
  25. #18
    R600a's Avatar
    Jul 2019
    Quote Originally Posted by ga-hvac-tech View Post
    Hey 600...
    This site:
    Easy $$$...
    That's pretty cool I never thought about offering pool services.
  26. #19
    Quote Originally Posted by R600a View Post
    Oh, one more thing...
    Inyo pools... (search it)...
    Best deals on pool parts and equipment.
    Lots of articles and videos on how to take care of a pool.
    GA-HVAC-Tech
  27. #20
    R600a's Avatar
    Jul 2019
    That is a nice website. Thanks.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
