+ Reply to Thread
Results 1 to 20 of 58
Thread: R404 walk in
    Jul 2021
    R404 walk in
    I’m n ac guy trying to help a buddy with walk in with r404. Can only get 20 degrees super heat liquid temp 112. 305 psi. Suc 50 psi. This is a new start up Txv is open all the way. Site glass is full amp 17 amp rated 22. Outdoor temp 82 box 45
    Southold, NY
    20* where. At the compressor fine at the coil no good.
    Is this a pressure limiting valve?
    Can’t accurately adjust until at or near temperature.
    Southold, NY
    Just read
    Put the damn valve back at mid point.
    Southold, NY
    kansas
    FYI you check superheat when box is close to temp 50psi sounds low for med temp 404
    Jul 2021
    24 degrees at compressor
    Jul 2021
    Box is 45
    Mar 2016
    NY
    Quote Originally Posted by Rleymarie View Post
    Box is 45
    Walk in cooler or freezer?
    “Happiness can be found, even in the darkest of times, if one only remembers to turn on the light.”
    "Ha! Memory is RAM!"
    Southold, NY
    24 suction temp or SH?
    Southold, NY
    And reset that valve to mid point.
    Virginia
    Sounds like your TXV is too small if you have it turned wide open and still only have 50 psi
    Ive seen it before ...
    Whats the number stamped on the valve ?
    Make sure the Nozzle was put in also
    Jul 2021
    Quote Originally Posted by Bombboy90 View Post
    walk in cooler 24 degrees super heat at compressor -- txv is full open
    Jul 2021
    sporlan SBQE w/external equalizer -- pink cartridge --- sporlan sized -- site glass is full -- what type head pressure this run at 90 degree out door box at 45
  14. #14
    Jan 2020
    Winnipeg Canada
    At 90 f 300psi wouldn't surprise me depending on condenser efficiency.
    350 probably wouldn't even be completely out of line....
    But obviously the lower the better.
    Pulling down a hot box will have elevated head pressure. If it's not tripping a safety then I rarely read head pressure until the box is down to temperature on a new install.
    After the box is down to temperature, then you start measuring superheat and head pressure. Until then you are wasting time.
  15. Likes flangatang7 liked this post.
  16. #15
    Jan 2006
    In a land far, far away
    Moved to Refrigeration forum
  17. #16
    Jan 2010
    Without knowing the box size, compressor size, evaporator size " pink cartridge " means nothing.
    Well other than it's rated at 1.5 ton.
  18. #17
    Oct 2011
    Harrisburg, NC
    Cooler or Freeer?
    Can only get 20 degrees super heat liquid temp 112. 305 psi. Suc 50 psi. This is a new start up. Txv is open all the way. Site glass is full amp 17 amp rated 22. Outdoor temp 82 box 45
    None of this tells us anything without the following:
    Box size
    Evaporator Model
    Condensing unit model (not compressor)
    You gave use the TXV size, as 1.5 ton based on how it’s built. But what power element, and why a SBQE instead of an SQE? I personally do not use balanced port valves except for a purpose that specifically calls for it (eg, flooded evap, some ice machines, smaller single pass evaps) but that is my preference.
    Liquid/Suction line sizing.
    Suction pressure at the condenser
    Suction pressure at the Evap.
    I can't fix it if it won't stay broke..
  19. #18
    Jul 2021
    Quote Originally Posted by BadDaddy420 View Post
    Cooler or Freeer?
    Box size
    Evaporator Model
    3/8 liquid line
    7/8 suction
    box 12 x 24 x 8
    50 psi at compressor
    condenser AVA7523ZXNXC 3 HP TECHUMSA
    EVAP CEL0250AS6AMAB0000 HEAT CRAFT
    A LITTLE HISTORY -- WHEN I ARRIVED IT HAD A SBQ BODY WITH INTERNAL EQUALIZER , KT43JC ELEMENT AND A C CARTRIDGE --- CALLED SPORLAN GAVE ALL INFO THIS IS WHAT I GOT
    SBQE BODY
    KT43SC/PC ELEMENT
    B CARTRIDGE
    IT SEEMS THE EVAL IS STARVING ???
    7 DEGRTEES TD ACROSS COIL
    DID NOT CHECK SUCTION AT EVAP
  20. #19
    Sep 2016
    PL In New York
    I'm anxious to know what the problem was. Does it make temperature and shut off eventually? How far is the CU from the evap? Above or below?
  21. #20
    Oct 2011
    Harrisburg, NC
    R404 walk in
    3/8 liquid line
    7/8 suction
    This should be fine.
    box 12 x 24 x 8
    Btu Required is 12,960 with heavy use.
    EDIT: That was off US Cooler’s website. The HeatCraft chart states around 20,000btu. So that’s sized correctly as well.
    This is, if I remember, about a 5deg sst. That’s too low. I’ll get to what’s up. I think.
    Condenser AVA7523ZXNXC 3 HP TECHUMSA
    Capacity 21,460btu
    Capacity 25,000btu
    SBQE BODY
    KT43SC/PC ELEMENT
    B CARTRIDGE
    This is a 1 1/2 - 2 ton Balanced port External EQ
    Install a SQE 3x4x2 with a Black/#5 cartridge and a KT43SC power element (which you have).
    I believe that will solve your problem. I honestly do not think the balanced port will open up enough with the cartridge that is in it.
    I’d suggest going with the White C cartridge for the balances port you have, but I don’t know if it will throttle down enough when the box gets to temp and load is down.
    Someone else may disagree. But that’s my pennies worth.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
