Results 21 to 34 of 34
Thread: Measuring whole house watts for generator
  1. #21
    Deep Southeast
    Quote Originally Posted by heatingman View Post
    How does the wattmeter account for imbalance between L1 and L2 - IE more 120v load on one line?
    I always thought watts for a split phase panel was
    Watts = volts x (L1 amps + L2 amps / 2)
    It doesn't, AFAIK. The KWs were slightly higher when I switched to 'L2'.
  2. #22
    Deep Southeast
    Thought this might be of interest. This guy measures amps of the compressor with HSK, without, and then with a softstart, which reduces the start amps significantly and, according to some, extends the life of the compressor. Very pricey though.
  3. Likes R600a, dieseldude, STEVEusaPA liked this post.
  4. #23
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    Quote Originally Posted by vin lashon View Post
    That basic test has been done by many people. thats why I say a hard start doesn't reduce inrush it just changes the duration and often changes the reading that a meter that takes a timed snapshot amp reading shows but I soft start (not a grenade/ptcr) actually reduces it.
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
  5. #24
    Jan 2012
    Broomall, PA
    Quote Originally Posted by R600a View Post
    I bet @Jayman could be coaxed into a video with some of his testing equipment
    If I do a job in 30 minutes it's because I spent 30 years learning how to do that in 30 minutes. You owe me for the years, not the minutes.
  6. Likes R600a liked this post.
  7. #25
    R600a's Avatar
    Jul 2019
    Quote Originally Posted by STEVEusaPA View Post
    I think he might have already posted a video on some aspect of that.
  8. Likes STEVEusaPA liked this post.
  9. #26
    Chicago area
    What kind of contactor is in that unit?
  10. #27
    R600a's Avatar
    Jul 2019
    The one in the video is an Emerson sure switch.
  11. Likes vin lashon liked this post.
  12. #28
    Deep Southeast
    https://climate.emerson.com/en-us/sh...:&facetRange:&
  13. #29
    Chicago area
    Are those common? Never seen one, and Im exposed to all sorts of system types and sizes.
  14. #30
    R600a's Avatar
    Jul 2019
    Sounds like you answered your own question.
    I want to run one on my system but I don't want to spend the money.
  15. #31
    Mar 2013
    Treasure coast, FL
    Definitely not common. I've never seen one in the wild and haven't found a need to use one for it's stated purposes - keeping out ants and other debris.
    It's like $50 for a 30 amp rated contactor. I suppose if your 2 ton unit is oversized and cycling enough to wear out a properly sized or larger definite purpose contactor, then maybe the 5x contact life would be worth it.
    Sent from my motorola one 5G UW using Tapatalk
  16. #32
    Deep Southeast
    Northern Calif
    Just install a mercury contactor, if you have the room, and never look back…mines 25+ years, no issues.
    I'm not young enough, to know everything...
  18. Likes R600a liked this post.
  19. #34
    R600a's Avatar
    Jul 2019
    Quote Originally Posted by dieseldude View Post
    I was mixed up. I thought he was referring to a soft start. I thought about using a sure switch but it's too much electronics integrated into a simple part and I picture it going down after a thunderstorm where it would otherwise have been fine. Id rather use a mercury contactor or just replace the contactor every 10 years and treat the ants regularly.
